  1. Option three is a plug-patch. That is a patch (done from the inside) that also has a plug attached to it. So, the plug is pulled through the hole securing the patch on the inside of the tire - all are glued.
  2. US or RoW? stock or sport? If you are changing suspensions I think you want a kit that includes springs, shocks and sway bars?
  3. If you hear a horn beep when you lock the doors that means you have an alarm zone open (or not functioning). This could cause the alarm to trigger. The alarm system has it's own horn/siren. The alarm system has it's own controller and fuse C3 - and it is 15A. The fuse B3 is 25A (not 30A) and is for the driving two tone horns - operated from the steering wheel.
  4. Dealers were supposed to replace the 00 caps long ago -- but many were missed. The 00 caps are known to leak. The newer 01 caps (usually) don't leak.
  5. 996.642.122.03 EFR was used through model year 2001 996.642.122.12 EWD was used in model year 2002 (pre MOST and PCM2) If you have an older version of PCM in your car you will need to re-program the instrument cluster to match the PCM unit or your total mileage and fuel consumption will not match the PCM unit.
  6. I doubt it. I would ask them to show let me drive another 997 Tip that makes the noise. If other cars don't do it - then (IMHO) it is time to take it to your Porsche Regional Rep.
  7. I don't think you need any relays. Did you see the DIY here?
  8. Yeah, if the old cap wasn't leaking then it might be worth a try. I guess you might have a bad new cap?
  9. Assuming the new tank did not crack when you put it in. You didn't say that you replaced the cap or not? What are the last two numbers on the cap part number? If it is 00 then it needs to be replaced.
  10. They might work but Porsche uses different spring rates and shock stiffness for coupes and cabs. As well the Tip and 6 speed matter also. It is all a case of weight and balance - Porsche's running are "tuned" to the cars options/weight/balance. Stock springs will raise the car up some and soften the ride some at the expense of some handling.
  11. http://www.renntech.org/forums/index.php?s...dpost&p=997
  12. There are several hundred things that can cause a check engine light. Without the fault code(s) you are shooting in the dark. Go to an Autozone and have them read your codes for free. Then post them here.
  13. Have them check the ground (connector) wires under the seat also.
  14. I would use some electrical contact cleaner.
  15. We have added and/or updated TSBs in the following categories today (19 total): Boxster (987): 4 Cayman (987): 3 Carrera (997): 3 Cayenne: 5 General/Literature: 4
  16. Because of the demand for disassembling sun visor - here it is: 1. Unclip mirror insert 3 -- Insert a narrow screwdriver between the mirror insert 3 and the mirror housing 2 at the bottom center, and unclip the mirror insert. 2. Remove mirror insert 3 -- Pull the mirror insert 3 upwards and remove from the mirror housing 2. 3. Remove bulb 5 and contact clips 4 -- Remove the 12V /3W bulb 5 from the contact clip 4. Take the contact clips upwards out of the holder. 4. Unclip mirror housing 2 -- Insert a narrow plastic spatula between the mirror housing 2 and the sun visor 1 on the left and right and unclip the mirror housing. 5. Remove mirror housing -- Take the electric lead out of the mirror housing 2 and detach the mirror housing from the sun visor.
  17. If you want to know what the fault code (and cause) is -- then you will need the Durametic Software or a shop with a Porsche PST2 or PIWIS tester. The most common problem is bad electrical connections on the buckles (either side). The fault code will tell you which one it causing the light.
  18. What color is the second wire? (brown is almost always ground)
  19. If you want to know what the fault code (and cause) is -- then you will need the Durametic Software or a shop with a Porsche PST2 or PIWIS tester. The most common problem on the vintage car is bad electrical connections on the buckles. The fault code will tell you which one.
  20. 1. Removing cover trim -- Remove the cover trim 1 at the left and right towards the front. 2. Undoing fastening screw -- Unscrew the fastening screw 2 at the left and right. 3. Pulling out the sound package -- Pull the sound package 3 in the direction of the arrow out of the bracket 4 and fold over. 4. Disconnecting the plug connection -- Press plugs 5 together and pull apart.
  21. I manually corrected this for you. In the future please realize that you can subscribe (to email notifications) for topics or forums. You were subscribed to a forum. To change your preferences just go to My controls -> Subscriptions and then choose View Topics or View Forums. Check the box for the subscription that you want to change and then use the dropdown box to change email preferences or to unsubscribe.
  22. In front of the radiators (see pic below) Have a look at my 3rd Radiator Install DIY for more pics http://www.renntech.org/forums/index.php?showtopic=7070
  23. You are correct that on a TT the clutch and brake system are completely separate and even use different fluids. One should not effect the other. If bleeding or pumping the brakes does not improve the pedal feel then the problem is likely pad taper or the pads were overheated or the pads were not bedded in properly. Usually when it is a bad master cylinder you can detect bleed down when holding the brake pedal down. Has the car been driven since the brake pad and fluid change? and were the two done together at the same time? Was the ABS/PSM system also bled?
  24. Yes, change it now and at least every two years going forward. If you track the car then plan on 2-3 times per year.
