  1. P0740 Fault, torque converter clutch - present Possbile causes: - ATF supply - Torque converter - Pressure regulator 4 (hydraulic) - Electrical triggering to pressure regulator 4 - Hydraulic control unit
  2. http://www.whiteson.org/boxster/mods/obc/
  3. Have a look at Cayenne TSB 12/05 9153 Satellite Radio Installation Instructions (I No. QV4 QV8) -- dated Sep 19, 2005.
  4. Clean the MAF again and if that does not fix I think you will need a new MAF.
  5. Only the 124 MAF is approved for use with a 996TT.
  6. I don't think it is a problem. Ask a fellow Boxster owner (or dealer) to let you listen to another car. I think you will find they all do this.
  7. Try Performance Products or Sunset Imports (Porsche Parts at Dealer Cost). :welcome:
  8. or a shop (or individual) that has one. Very small. Most folks do not worry about it.
  9. TT, Carrera, and Boxster all use the same switch. The switch itself is cheap - some folks choose to spend $200 and upgrade the switch and lock to the newer version (there is a TSB on this for all three models).
  10. If you are sure the clutch switch is working then you either have a bad ignition switch or the starter is bad. Usually starter don't just "not work" they sputter or are intermittent. Any other weird electrical problems lately? Bad ignition switches sometimes cause other weird electrical problem.
  11. I'm not sure on turbos as I have seen many. But, on Carrera's and Boxster it is usually everything except the AC compressor.
  12. Have you checked replacing the bulbs in your owners manual? I think you have to take the lens off for that.
  13. For a MY 99 the 993.113.245.01 is the correct part. Sometimes one fault can cause another fault.
  14. Just when you start to back up or does the rattle continue? Could be a partially plugged line or a bad motor or a leak. Most of the tank and pump are under the left front fender (even on RHD cars I think).
  15. Try bypassing the clutch switch if it is not that then you may have a bad ignition switch.
  16. Yes, it sounds like a vacuum cleaner to me. It usually runs only about 5 minutes. It is for emissions.
  17. You can always get the B&M shifter. It pretty much works and looks the same - except it is blue and the Porsche one is gray.
  18. It's not too hard to clean the carbon from the throttle butterfly. It has been covered many times here - try doing a search.
  19. Take your car back to the dealer to fix it under warranty. Could be the alternator.
  20. Hmm... Porsche's parts list calls out 996.606.124.00 for all years 996TT.
  21. Thanks for catching that oversight. Should be all fixed now.
