  1. Are you sure P0430 is the only code? Many times there is another code that indicates a bad O2 sensor (as Chris_in_NH said). P0430 says you need a new cat. Please double check that you don't have any other codes.
  2. Lighter should be D5 not C7.
  3. You've got mail...
  4. 1. Fault code 5525 -- Torque transmission from the DME disturbed at times I have seen this on almost every TT I have looked at. I think it is normal for the power/wheel slip the car has. 2. No Porsche leaks "normally" - period. 3. Really have to hear that one to be sure. Did they tell you what the DME had for stage 1 and stage 2 over revs? Stage 2 are the bad ones - should be a very low number or zero.
  5. Yes, the Tip in the 3.6 liter Carrera is the same as the TT.
  6. That is the correct number. 996.107.225.52 was replaced by 996.107.225.53 and was replaced by 996.107.225.60. Any of the three will work fine.
  7. Sorry, I misunderstood... The GT3 spoiler is 997.595.983.92 Self-tapping screws 999.073.227.09 Captive nuts 999.507.590.02
  8. You've got mail....
  9. As a Contributing Member you can view all the aerokit information (including part numbers) in the 997 TSB 1/05 6658 Aerokit Cup (I No. XAA) -- dated March 16, 2006. I do not know if it is a "bolt on" - I have doubts since the aerokit front bumper has a different shape than the stock one. But, we won't know until sometime tries ;)
  10. Did you know there is a DIY here and some of the photos are from a TT? I sent you a PM.
  11. Very little difference. Just realize that if it came out of a MY00 car then it likely has egas which your older car likely does not have. It is not too hard to change the intake from one old engine to the replacement. It would be harder to find a DME for for the egas engine (and other assorted parts).
  12. Yes, that part number is correct. It just changed this month (October 2006).
  13. The Retail Price Search feature (for our Contributing Members) has been updated to reflect October 2006 pricing for the US (only). We try and update this on a monthly basis as the price lists come available to us. For October 2006 the price lists support - US: 207,852 parts Canada: 207,853 parts
  14. It might have been one of the last MY02's before the MY03 production. For example - my MY99 Carrera has many of the MY00 updates and my car was built in July 1999 (the last production month for MY99).
  15. You likely don't need a PET program. You can download free parts listings (taken from PET) at Porsche's Technical website. Click on the link here and then choose your country. After that choose Workshop Information then Genuine Parts. Choose your car model and then download the parts listing. (You can also find this link in our Links tool at the top of any page).
  16. The part numbers are the same for MY97 to MY02. There are different part numbers for MY03 on.
  17. The part numbers you gave above are not valid - so yes the part numbers are different.
  18. For a MY00 Boxster S 6 speed: Front US M030 springs - red/white Rear US M030 springs - violet/yellow
  19. Standard or Sport?
  20. Well, it could be a hose I would still bet on the tank. Especially if the leak is on the left rear exhaust/wheel area.
  21. Yellow/White are US M030 for a MY03- Boxster/S front springs Orange/Brown are US M030 for a MY02- Boxster S rear springs
  22. Yeah, if you read the posts further down another member had to force a guy to do it EXACTLY like I said -- then it worked.
  23. http://www.renntech.org/forums/index.php?s...ost&p=53645
  24. Have a look here first. It's the same process on a Boxster or C2. C4 is slightly different.
  25. The only difference between the two kits is the pressure plate. Porsche now uses the same flywheel for all Boxster (-05) which means it should bolt up. probably just a spring rate difference. I would go withe the "S" kit but you can always double check with JeffClark@sunsetimports.com
