  1. Two beeps means there is an alarm fault - one beep means there is an open zone. You need a Porsche specific scan tool tester to get the fault code(s) and diagnose what is needed to repair. An excellent Porsche specific scan tool is Durametric but a few other tools may work as well.
  2. The seat belt and grounding issues were fault codes 45, 46, 48 and 49 - per the TSB. This fault 28 which is the drivers side (door) airbag.
  3. You need a special Porsche airbag test fixture to test airbags - I wouldn't go there. You can check the wire going to the airbag to make sure they are not pinched or broken in the door panel fitting. Do this with the key out of the ignition and the battery disconnected.
  4. Fault codes 12, 13, 28, 29, 40 - Ignition circuit, driver's side airbag Possible cause of fault: - Short circuit to B+/grouncl or open circuit in the wiring between the driver's side airbag unit and the airbag triggering unit - Driver's side airbag faulty
  5. What happened to the radio and radio code I gave you last year? Try 7269
  6. Alarm chirps and Locking chirps sound very different. Which is yours? a normal locking sound?
  7. If you have two alarm chirps when locking then you have an alarm fault. You should also have alarm fault codes - please post the codes.
  8. Maybe Durametric... if not then it will take a PIWIS tester. A few shops have PIWIS.
  9. Exact model and year of your car, please?
  10. Yes, likely the nut on one of the spindles or a stipped spindle.
  11. Broken wire, shorted wire, blown fuse, bad DME.
  12. If that is the only fault you have trying re-calibrating the suspension system.
  13. The DME may not be supplying the +5 VDC to the camshaft sensor.
  14. Whenever I hear of an electrical issue with a Cayenne (or any newer Porsche) the first thing I go to is the battery. These are are very sensitive to weak or dying batteries. If your battery is 4 years old or older I suggest you replace it (even if it's not the problem).
  15. If you are changing wheels make sure of the wheel offset - otherwise, there will be contact or rubbing issues.
