  1. On a 986/996 they are held in by screws. In looking at the 987 parts list I do not see any screws - so they may just be glued in.
  2. http://www.renntech.org/forums/index.php?showtopic=392
  3. Yes, but you will need to run a wire from the sending unit to the cluster. Do a search I think Tool Pants covered this before.
  4. Here is the post I was talking about http://www.renntech.org/forums/index.php?s...ost&p=27952
  5. The latch is very similar to the latch used on the 986 and 996. There is a DIY adjustment procedure in the 996 DIY Common Fixes section. But... since the car is under warranty why not let your dealer fix it?
  6. LOL... I think not I learn something new every day. Many times from other knowledgeable folks here.
  7. Sorry, no. Different engine and exhaust system.
  8. Those are twp piece wheels and the outer rim is not painted - nor are the bolts. To paint it properly the wheel needs to be disassembled, painted and then re-assembled with the proper torque sequence on each bolt (IMHO).
  9. As does TSB 4440 - for each model.
  10. The following is provided by one of our Contributing Members. Sirius Installation Instructions - Porsche 997 C2S For Car With BOSE But No NAV Or CD Changer DISCLAIMER: PROCEED AT YOUR OWN RISK- YOU WILL PROBABLY VOID YOUR WARRANTY AND YOU MAY RISK CAUSING DAMAGE TO YOUR VEHICLE FOR WHICH YOU WILL BE SOLELY RESPONSIBLE. BACKGROUND: This installation was performed on a C2S model with the latest PCM software, the Bose audio option but no CD changer or NAV option installed. These instructions are SPECIFIC to a car without NAV or the CD changer as there is no fiber optic cable to pick up a connection near the position you will mount the SIRIUS unit. You will therefore have to pick up the fiber optics closer to the amplifier in the lower portion of the luggage compartment adjacent to the luggage lamp. It is a slightly more difficult installation than one for a vehicle with an existing NAV or CD changer. Vehicles with NAV systems (and/or CD changers) will have a fiber optic cable closer to the SIRIUS unit that can be disconnected and run through the cable supplied with the kit. In these cases, there should be no no need to replace the fiber optic cable from the amplifier and as pictured elsewhere in the forum should be a simpler installation. In contrast with previously described installation instructions, it was NOT necessary to remove the cowl and windshield wipers or disconnect hoses and wires fed through to the cowl. Order Sirius Cayenne kit (specify that you want Sirius for the CD changer option whether you have a CD Changer or not) - the cable is required for this installation. No cutting, soldering, or wire splicing was necessary for this installation. Everything is essentially plug and play but the difficulty lies in removing plastic panels, getting access to the various components, and identifying the correct cables (and plugs) necessary for the installation. I would NOT recommend this as a DIY project for anyone who does not have a good amount of experience with electrical work, automotive/audio electronics, or sophisticated computer equipment installation. There are three major cable runs. 1) Power from car to SIRIUS unit, 2) bypass of the fiber optic cable that travels from the car to the audio amplifier through SIRIUS unit, and 3) antenna cable from SIRIUS unit to antenna mounted under cowl. There are two items that need to be mounted: the SIRIUS unit itself, and the multi-purpose antenna (plugs for SAT and GPS). NOTES: I found it necessary to dismantle the fiber optic / power supply cable bundle by removing the black spiral adhesive tape and white adhesive labels separating the orange fiber optic cables pair from the power supply cable. I also separated an antenna wire pair from another bundle with other lines and tubing specific to the Cayenne and unneeded for the 911 install. There was one orange fiber optic and one antenna cable left over at the end of the installation in addition to a myriad of other Cayenne specific small parts. The Cayenne satellite install TSB is worth reviewing but is largely useless for this installation. Note that all fiber optic plugs have black plastic protective covers which must be removed before they are connected. Perform all installation procedures with the key turned off and removed from the ignition. Porsche seems to recommend disconnection of the battery for electrical work on their vehicle. STEP BY STEP: 1. Remove ALL accessible plastic access covers from interior of luggage compartment with the exception of the headlight/turn signal access panels. You will need to access to the area where the CD changer and NAV are usually mounted, the area under the cowl above the cabin air filter, and the amplifier component stored behind the flat tire tools. I removed the largest plastic piece (requires removal of approximately 4-6 phillips screws) and disconnection of the luggage compartment lamp effected by pulling a small plug from a receptacle just behind the lamp. Note its orientation when you disconnect it so you can reconnect it properly at the end of the installation. Other panel and carpet fasteners are removed as needed. The cowl directly under the windshield wipers may be left in place (it can not be removed without the disconnection of windshield washer tubing and removal of the wiper themselves). 2. Remove the molded carpet pieces in the CD changer / NAV area (passenger side of the luggage compartment) and place the Sirius unit towars the center of the luggage compartment with cable receptacles facing forward. I secured the unit at the end of the installation with two sheet metal screws through the carpet into the metal frame designed to hold audio components. (This is shown in photographs in other posts). Plastic ties would work nicely here too. 3. Locate the spare (and hidden) BLACK/WHITE/RED/BROWN power supply plug tucked beneath the carpet on far left side of compartment which you will need to bring power to the unit. Plug one end of the supplied power cable into this plug and the other end into the Sirius unit. Note that this may not be possible (plug won't physically reach power supply) unless the power cable has been separated from the orange fiber optic cable in the fiber optic bundle and re-directed in the opposite direction. There will be a remaining unused plug on this cable (on the power supply end) which can be used to power a CD Changer or NAV should you add it later. 4. Locate the ORANGE fiber optic plug which plugs into the amplifier (component with ventilation fins behind the tire repair tools) behind its wiring harness. This plug is hidden from view and is NOT clearly visible. It must be traced from a bundle of the car's wires just to the right of the amplifier unit near the luggage compartment lamp on the driver's side of the vehicle. 5. Identify the ORANGE fiber optic cable supplied in the kit with MALE -and- FEMALE plugs that branch off approximately 4 to 5 inches from each other forming a 'Y'. Work with this end of the cable for this step. 6. Locate the ORANGE fiber optic cable (with a black plug) connected to the amplifier just behind the wiring harness (and out of sight) and disconnect. Plug this male component into the FEMALE plug on the end of the MALE/FEMALE cable end as described above. Connect the MALE plug into the amplifier behind the wiring harness. Be very careful not to damage, crush, or over-bend the fiber optic cable which runs as part of a bundle from the car as failing to do so will necessitate a very expensive not covered by warranty service visit. Remember that fiber optic cables have a bend radius that if exceed DESTROYS the cable and will also make future troubleshooting difficult. Plug the opposite end of the cable (also a MALE) into the Sirius unit after feeding and routing the cable under the carpet. 7. Plug the antennae cable (brown/green) into the receptacles on the Sirius unit. Locate the purple dual antenna plug on the opposite end of this first antenna cable and connect it to the dual purple plug of the second antenna cable. When the two antenna cables are connected (via the purple plugs) there will be 15-20' of antenna cable left to coil and tie off. Feed the WHITE and PURPLE 90 degree (right-angle) plugs through an available rubber grommet securing it as needed with ties along the way and run it to a space just over the air filter. At this point, you connect the Sirius antenna with the black side facing up. It should be especially snug in the position under the cowl and over the air filter and can be further secured with double sided tape as needed. Note that it may be possible to better secure the antenna (without removing the cowl) by removing the air filter and its enclosure. There should be a receptacle on the underside of the cowl for a phillips screw to secure the SAT/GPS antenna. A flat ratchet wrench type screwdriver with an offset should allow you to drive the screw in the limited space available but I have not experimented with this approach yet. 8. Tie up loose cables with supplied plastic ties. Run wires where possible under carpet and be sure to take care to protect the orange fiber optic cables.. Record the SIRIUS I.D. # in the small print (not the CRIN #) from the label on the unit which you will need for activation. Replace plastic panels. Make sure the car is located outside with a clear view of the sky in all directions. Turn ignition to ACC position. If for some reason, PCM doesn't power up or appear to be functioning normally, you have made a mistake and should go back and check your work. 9. Press Audio button and Press FM/AM band select button and PCM should recognize the satellite unit and show the message "acquiring signal". The default channel is 147 or 148 and you need to hear the programming before proceeding or you must go back and check your connections. Contact Sirius with the unit's ID # to receive 3 free months and activate the unit. Total working time was 2 hours and 30 minutes exclusive of activation with almost 50% of the time spent identifying unfamiliar parts. I believe I could do a second installation in 90 minutes or less.
  11. Sirius Installation Instructions - Porsche 997 C2S The following is provided by one of our Contributing Members. Sirius Installation Instructions - Porsche 997 C2S For Car With BOSE But No NAV Or CD Changer DISCLAIMER: PROCEED AT YOUR OWN RISK- YOU WILL PROBABLY VOID YOUR WARRANTY AND YOU MAY RISK CAUSING DAMAGE TO YOUR VEHICLE FOR WHICH YOU WILL BE SOLELY RESPONSIBLE. BACKGROUND: This installation was performed on a C2S model with the latest PCM software, the Bose audio option but no CD changer or NAV option installed. These instructions Author Loren Category Carrera (997-1) - Mods Submitted 12/10/2006 08:35 PM
  12. Here is the last Bosch chart I have.
  13. Paul, There is no difference between the ATE Typ 200 (gold) and the ATE Super Blue. Only the color is different - the specs are the same. Switching between blue and gold is just easier to see when you are doing a flush/bleed.
  14. Porsche didn't start producing owners manuals in PDF form until MY2003 - so anything prior to that had to be scanned in by someone. Try the folks at Sunset Imports (Porsche Parts at Dealer Cost). The last (printed) owners manual I got from them was $18.
  15. Most likely the bulb needs to be replaced. Do a search here for "+cluster +bulb" and you should find some tips.
  16. And you still have all of your fingers? ;) ;)
  17. M446 CONCAVE HUB CAPE WITH COLOURED ESCUTCHEON M226 may be a country code - what country? M750 does not show on listing I have.
  18. 1 & 2 sound like a bad ignition switch. 3 could be the same as a bad ignition switch will cause some strange electrical problems. The switch panel where the door locking switch is comes off easily if you want to look for a loose connection (perhaps from the previous owner changing the radio).
  19. Both the AC and Power Steering high pressure hose are over there (I can't tell which one from the pic). Follow the leaking hose back to either the compressor or power steering pump to find out.
  20. http://www.renntech.org/forums/index.php?s...ost&p=55764
  21. 986.424.010.04 is the only shifter assembly in the parts list for the MY04- GT3
  22. Personal Profile Portal RennTech.org has a totally redesigned personal portal page with the following features: Friends list - manage your friends for easier PMing, to see if your friends are currently online and display your friends on your profile Profile comments - allow visitors to leave comments on your profile. You can set to moderate all new comments before they're shown. Recent visitors - recent visitors are shown on your profile. Your content - show your recent posts / blog entries / gallery uploads on your profile Personal statement - add a short bio for others to read Member rating - rate other members Set your gender Easy access to edit your location, age and IM details Friends List: Reciprocal Adding. When approving friends you can choose between "Approve & Add to my list" and "Approve Only". Friends List: Mutual Friends List: View who you've added and who's added you. Profile: Profile View Counter Profile: Ability to set the number of last visitors, comments and friends in the sidebar Profile: Ability to use basic BBCode for formatting the personal statement Member List: Ability to sort member list by profile views. Tool to convert previous versions contacts into new versions non-mutual friends Tool to convert previous versions photos to new versions Profile Photos New Text Editor New Style The text editors, both standard and rich text (WYSIWYG) have been completely rewritten to make them more intuitive and faster to load. Clutter has been reduced with the new dynamic menus. Switch You can now switch between the rich text editor and the standard editor without the need to reload the page or visit your User Control Panel. New Attachment System Upload without the reload RennTech.org has a new attachment system that enables one to upload attachments without having to reload the post screen. The new attachment area is directly below the text editor. New Style The attachment system has had a complete overhaul and is now styled along side the new text editor New Spoiler and Acronym tags There are new Spoiler and Acronym tags that you can use in posts. A Spoiler tag hides text until someone highlights it with their mouse. For example: You see this Acronyms are great for explaining a term or phase. Just position your mouse over the dotted unlined word to see it's meaning. For example: If disable your ABS you will have trouble stopping the car in an emergency. New Thumbnail Design Attached image thumbnail previews now have information above and below the thumbnail offering original file size and original dimensions. Inline message system RennTech.org has an on-the-fly message system to confirm actions taken place. This is an important new part to the user interface especially when using ajax when it's not always apparent that an action has taken place. Auto resizing of large linked images Posted images are automatically resized on-the-fly if they are larger than the available screen width of the browser. Clicking the image displays it full size in a pop-up window. Each reduced image has information above stating how much reduction has taken place and the dimensions of the original image. Ability to reset password by email or username If the login type is 'username' a second field on the reset password screen will display to allow a user to reset their password by their email address. That is, they can enter their email address (i.e. if they forget their username) and the process will proceed as normal. Reviews Section The Reviews section will be re-done to a new/better/more compatible system that interfaces with the forums better. I hope to convert all the existing product reviews to the new system when it is ready. Edit - The Reviews section will require you to login (at the Reviews page) in order to reset the cookie for that application. You should only need to do this once (for each computer that you use). I likely missed a few new features so I will try and update this posting as time goes on. Please let me know if you see any errors or mistakes. Thanks!
  23. I do not know the differences. Jeff (Tool Pants) and I have looked at many of these and we can not see anything different. If there are differences they are very subtle. Together we have likely installed several dozen B&M SSK kits and they have worked on all versions of the factory base shifter.
  24. No, the Carrera (996) uses: 996.424.010.04 for MY02 and older 996.424.010.05 for MY03 and newer or for MY04 and MY05 you can use the factory short shifter 997.424.983.00
