  1. Maybe a rock or pebble stuck between the rotor and heat shield?
  2. Look for some similar posts here and in the Boxster section (same A/C mechanism). I seem to recall some issues with foam or weatherstripping hitting the fan.
  3. Most likely something as simple as a microswitch. A PST2 or PIWIS will likely narrow the problem down. Where are you located? Do you know an independent or a friendly dealer with a PST2 or PIWIS?
  4. Remove the wheel to get better access. Well, you might want to pick up some of the plastic rivets that the fender liner in place - if they are very old they will likely break when removed. I can't remember there being much room to work (if you have big hands like me) but you should have enough room to push it through the hole while you put the rose back on. I wouldn't think it would take an hour - and you might be able to just pull that section of the fender liner back rather than removing the whole thing. So maybe a 3 or 4.
  5. As I recall you should be able to get to that by removing the inner fender liner.
  6. If you mean the rectangular frame that goes around the climate control then it is 996.552.677.00.01C. If you mean what is inside of that frame - then that is the control unit itself - and that will be expensive.
  7. I am getting the rear spoiler failure light. Spoler does not go up. What should I do? Thanks David Under what conditions? What model year car? Standard, or aftermarket spoiler?
  8. Just to clarify... The standard rear tire on MY99-MY01 with 18" wheels was 265. MY02 and newer got 285's. There is no problem running 285's on the standard wheels. Porsche did that on the GT3 Mk1 and I have been running 285 rears on my MY99 car for over 6 years.
  9. Only Moderators or an admin can change a topic title "after the fact". I have edited the title here.
  10. There is a TSB on this dated 9-28-01. Basically Porsche changed the heat range from a 5 to a 6 on cars build after August 14, 2001. Any and all replacments are to be the newer plug (heat range 6). The correct plug for all TT and GT2 is 999.170.195.90.
  11. You did check the fuse in the front trunk? Panel 1 (center panel of 10 fuses) fuse 3 -- should be 25A
  12. You are the man! Board should be called LORENTECH.ORG Thanks again. Joe :lol: :lol: :lol: :lol: There are many knowledgeable folks here... I just have too much free time... :P
  13. The alarm system goes through a self-test and a zone test prior to arming. During this preset test the alarm light to flashes at twice it's normal rate (twice per second) until all zones are checked and the alarm goes into "armed" mode. Then the alarm light flashes normally (about once per second).
  14. Page 76 of the MY03 Boxster Owners Manual
  15. Part 2... Because of your water damage you may want to check these ABS ground points too. Ground point 2 = The ground point is located on the left in the luggage compartment Electronics ground = The ground point (arrow) is located on the dashboard support frame (A)
  16. For MY99 1. Control module 2. Relay 3. Fuses 4. Speed sensors 5. MILs and information lights 6. TC (OFF) rocker switch with light
  17. :lol: :lol: :lol: a bit off topic here but I did get a chuckle out of the instructions pic with the word "Illustrationation". I think something got lost in the translation...
  18. Most dealers in the bay area give minimum discount of 10% to PCA members. It looks like Sunset's price much better than that (plus no tax). I doubt any bay area dealers have one in stock either.
  19. There have been a few of these. Have someone with a PST2 or PIWIS look at your CDR23 fault codes. The problem is usually a bad radio or bad amp (I think I've heard of more bad amps).
  20. MSRP is $5502.93 -- and they quoted you list price. You might want to check with Sunset Imports (Porsche Parts at Dealer Cost) for a better price... 9 hours sounds a little steep to me. I would estimate 2 hours actual labor - likely 4 hours total including testing, gear oil, etc.
  21. All of the Tip test procedures are in the OBD II manual for MY99. I would certainly walk through the tests and the actual readings and then compare them against a know good running Tip. The PST2 can read: Input signals can be checked and read out with this menu: - Selector lever position - Selected gear - Multi-function switch - Kick-down switch - Downshift switch - Upshift switch - Manual program switch - Stop light switch - Traction Control The following actual values can be read out with this menu: - Rpm - Transmission input speed - Speed, front right - Speed, front left - Speed signal, transmission - Throttle plate angle - Transverse acceleration - Transmission temperature - Supply voltage - 1-2 shift, lower rpm range - 1-2 shift, medium rpm range - 1-2 shift, upper rpm range - 2-3 shift, lower rpm range - 2-3 shift, medium rpm range - 2-3 shift, upper rpm range - 3-4 shift, lower rpm range - 3-4 shift, medium rpm range - 3-4 shift, upper rpm range - 4-5 shift, lower rpm range - 4-5 shift, medium rpm range - 4-5 shift, upper rpm range - 5-4 shift, lower rpm range - 5-4 shift, medium rpm range - 5-4 shift, upper rpm range - 2-1 shift, lower rpm range - 2-1 shift, medium rpm range - 2-1 shift, upper rpm range - Map and The following drive links can be controlled: - Solenoid valve 1 - Solenoid valve 2 - Solenoid valve 3 - Coolant shutoff valve
  22. Check the wires on the sender unit http://www.renntech.org/forums/index.php?s...ost&p=54332 If it is not something easy like that then it is likely the sender or cluster. We have seen a few senders go bad. If you have access to a PST2 you can tell for sure http://www.renntech.org/forums/index.php?s...ost&p=54838
  23. I don't see a part number for LSD parts for a C2 after 1999. Only the 2004 Anniversary edition has an LSD and the part number is for transmission and LSD. 996.300.020.07 6-speed w/LSD -- MSRP $11,560.88 (does not include installation)
  24. http://www.renntech.org/forums/index.php?s...ost&p=32005
  25. When the front bumper cover is aligned it takes two people. With the bumper cover mounting screw/bolts loose align the bumper cover and tighten the screws. Close the front hood and check the alignment - if it is not right (even with the hood height) open the hood and re-adjust. Once the hood and bumper cover are aligned you can tighten the other bumper cover screws/bolts.
