  1. 1. Durametric. 2. Minor body changes 2015-2016, 2016 GTS model, 2017 Macan 4 cylinder. 3. I do not think there have been many air suspension failures or faults since 2016. Air is more expensive than steel but also has many handling advantages. 4. No, transfer cases are pretty much it for large items and most of those are replaced under warranty. 5. The VIN will not tell you anything about the options without a report from a dealer (we can also get reports for our Contributing Members). Download the option codes list here: https://www.renntech.org/files/category/140-macan/
  2. You need to re-train the windows. You do so by pressing and holding the button down - all the way down and an additional 10 seconds. Then do the same for raising the window. It's been covered here many times before so give our search a try next time.
  3. Try 1457 Please consider a donation to support this site - thank you.
  4. https://www.amazon.com/Porsche-Boxter-Radio-Removal-Tools/dp/B00XSAPF3G/ref=as_sl_pc_tf_til?tag=renntechorg-20&linkCode=w00&linkId=XCDIFRLMKX5YLRPI&creativeASIN=B00XSAPF3G
  5. READ the Lost Radio Code FAQ and follow the instructions there. I will only answer radio code requests in that one forum thread.
  6. Sounds like either the key or the lock detents are worn - or both are worn. You could try a new key before replacing the whole switch.
  7. The Registry is currently unavailable due to a software bug that causes it to hang. It will be back up once the author has supplied a fix for the error. Thanks for your patience!
