  1. Probably not. If you can't feel it then it is likely the tach. It might straighten itself out or it might get worse. Next time you are in to your dealer point it out to them so you go on record during the warranty period.
  2. Sorry, I misunderstood - I thought you had a hesitation in the powerband -- ignore my comment about that. I think your idle is within spec. You might try a bottle of Chevron Techron to clean the idle circuit. How many miles on your car? If you have over 40,000 miles you could have some carbon build-up on the throttle butterfly. If that is the case then you might want to get some spray carb/fuel injector cleaner and remove the air cleaner and clean the throttle butterfly. Especially the inside. That process is covered elsewhere here and is the same as it was on the 996 (or 986).
  3. Factory spec is: 670 ± 40 rpm The slight hesitation is likely the VarioCam cut-over point. There have been several discussions here about it.
  4. :welcome: Please try our Search function as many questions have been answered here (including this one) many times... http://www.renntech.org/forums/index.php?s...ost&p=55446
  5. 30 -- 999 507 040 40 expander nut 31 -- 999 073 080 02 tapping screw 32 -- 900 025 024 40 washer 33 -- 900 143 134 00 tapping screw 34 -- 999 591 498 40 expander nut 35 -- 996 701 801 00 spacer (left) (35) -- 996 701 802 00 spacer (right) 36 -- (not used on US cars) 37 -- 996 701 107 00 support (option 218) 38 -- 900 144 182 09 tapping screw
  6. If it is a good dealer (and since there is a TSB on the problem) they still might fix it for free...
  7. Is your car under warranty? This is covered in a TSB (most likely a bad amp) and should be fixed under warranty.
  8. The Service Reminder can be reset with the Durametric Software (about $247) or by any shop (or owner) with a PST2 or PIWIS.
  9. You are right power steering is Pentosin and it is a green color. Either way I would pull the front underside cover and see where it is coming from. Tool Pants had a leak in his steering box for a couple of years as I recall.
  10. :oops: I must have been asleep before... A MY02 996 cluster does not support CDR-23. MY02 still had CDR-220. Only thing that can I think of to try would be the CDR-23 setting in the DME.
  11. Green makes me think coolant. Red makes me think steering gear (power steering fluid). Is it oily or watery?
  12. Sounds like the emissions air pump near the engine to me. That will run for a couple of minutes at start up.
  13. Yes, Porsche shows different part numbers for Tip mufflers. I do not the difference.
  14. http://www.renntech.org/forums/index.php?showtopic=2950
  15. You can go up to a 235 in front with no rubbing and a 285 in the rear with no problems. You want to stay within 1-2% increase/decrease tire diameter (height).
  16. No, it just means that hte small amount of fluid in the ABS system is not bled unless you have the Durametric Software or a PST2 or PIWIS tester hooked up to open the ABS valve/pump. I have bled brakes many times without worrying about the ABS with no ill affects.
  17. http://www.renntech.org/forums/index.php?a...mp;showfile=947
  18. Laws vary by country... In what country? P0430 TWC Conversion, Bank 2 – Above Limit P1115 Oxygen Sensor Heating Ahead of TWC, Bank 1 – Above Limit Odd that it is reporting a cat problem on one bank (2) and an O2 sensor heater problem on the other bank (1). I would put a PST2 or PIWIS on the car and see if there are other codes...
