  1. He should be able to tell (with his PST2) if it is a cluster problem or a brake sensor.
  2. Yes. You also need him to use his PST2 to transfer the settings from your old cluster to your new (used) cluster.
  3. Mike, How do you get the dicount? I don't see it offered anywhere on the site (May 2)! I see the 996 version only goes up to '98. Just curious, do you know if it's good for the '99 as well? Thanks! That previous post was from May 2006 -- they have added a great deal to the software since then and cover many more model years and cars. I think you may have misread the cars covered. It is: 1996-1998 Porsche 993 and 1999-2004 Porsche 911 (996) plus many more...
  4. There is no weight sensor in the 996. The airbag uses the seat belt buckle to tell if someone is in the seat - that is why you need the special bar and programming when you use a child seat. So if you disconnect the seat belt buckle you will get an airbag (warning) light -- but the airbag will still deploy on a signal from the trigging unit. (Assuming the airbag itself has not also been disabled). If you put in a racing seat and racing harness you will need to get a spare belt end to put in the buckle or wire in a resister to simulate the buckle connected. If you are just driving on the street I suggest you stay with the factory belt/buckle system.
  5. Well, folks have bought the switch for under $10 on eBay and not much more than that at an Audi dealer. A good tech can change the switch in 5 minutes -- I've see them do it.
  6. The only other recall for MY03 TT was for a power steering hose (leaking) issue.
  7. Model Year? (it does make a difference)
  8. http://www.renntech.org/forums/index.php?s...ost&p=28639
  9. In the 997 and 987 the windows are managed through a controller in each door. I am still checking but it looks like the controllers in the Cayman and 997 are the same. If that is the case then it is a programming issue.
  10. Should be inexpensive - just tighten the bolts.
  11. 986 Boxster, 996 Carrera, 996 GT3, 996 TT, 996 GT2 all use the same crummy ignition switch. There is plenty of information here including different switch numbers as well as installation tips.
  12. Actually N-spec as defined by Porsche means: So I think it is more of a case that they have to be "Porsche tested - and approved". Contributing Members can read the Porsche N-Spec fact sheet in the Contributing Members forum.
  13. viper501 is correct - you will need a new DME and some wiring that is missing to make it run right. Todd Holyoak has written some DIY tips for a conversion for a Boxster. The good news is that you won't have to move any fuel rails (the engine faces the opposite direction in a Boxster). Todd's write is here.
  14. Please try using search next time - there is a whole section on this... http://www.renntech.org/forums/index.php?showtopic=7592
  15. What year is your car? ( so we know the DME version) and is it a C2 or C4?
  16. One of the most common causes is loose swaybar mounts.
  17. If you have the new shifter installed (the inside version) then the tool will do you no good - it doesn't fit the new shifter rod. If you count the threads from the connector end the left (reverse) cable is usually 4-5 threads and the right is usually 6-7 threads - at least in my experience. That should get you pretty close. If that doesn't work then you will likely have to borrow a standard shifter from someone - install it - then use the tool to align the cables.
  18. 996.631.05.00 Left reflector cover (orange) If you have Litronics (or upgraded your headlights) use: 996.631.45.01 Left reflector cover (clear)
  19. Well you need to test master and slave cylinders for internal leaks. If the slave cylinder is leaking, the outside of the casting will usually be wet with fluid and you will occasionally have to add fluid. If the master cylinder is leaking it will wet the inside of the firewall at the clutch pedal linkage.
  20. The gas flap (door) only locks when you lock the car (it is also alarmed). It shares the locking/alarm circuit with front hood.
  21. Contributing Members have access to this much more... ;)
  22. Just click on the Donate link at the top left of any page and follow the instructions.
  23. Well, either the master or slave could be leaking internally. The slave is high on the transmission and has a hydraulic hose going to it (also a bleed valve).
