  1. Eric at Bumperplugs.com sells plugs for the wiper hole.
  2. Well, I guess you could always take the cat off and shake it to be sure. Unless the break is near (where it could be welded) the end it likely means a new ($$$) cat.
  3. I think the two concerns are getting the wheel carrier down enough to get the strut out (and in) and not stressing the brake lines too much. There are only two bolts on the caliper so most folks just take them off and hang them on a wire out the way (so they don't have to disconnect the brake line).
  4. Should be three bolts and pull it off the gromment (toward the front of the car). Since you have headlight washers there will be two pumps and the various hose to disconnect. When you replace it make sure you get the right tank as the one for cars with headlight washers is slightly larger (996.528.701.00).
  5. Model and year of your car please? Also, with or without headlight washers?
  6. You mean like Porsche's KESSY (Keyless Entry keyless go/control unit) used on the Cayenne? I don't think it has been offered on anything except the Cayenne yet.
  7. Along with Izzy's suggestion - make sure that there are not more fault codes. Find a shop with a PST2 or PIWIS tester and have them read the codes (you should write all of them down). Then have them run the PST2 Tiptronic tests on your car. A DTC 30 is engine compartment temperature - which would have nothing to do wit the transmission.
  8. I think you could put a SSK in your car easily - but you would lose the shortened stick unless you cut the B&M down too.
  9. Hi Loren for information the company is NAVTEQ not NAVTECH. Interestingly on their UK site they dont list Porsche as one of their systems supported for upgrade but they do in the USA. The only update disc for 2004 listed in the US site is for North America Steve Seve, The information above is taken exactly "as is" from the Porsche TSB. We strive for accuracy here (even when Porsche is wrong). :lol: Search other threads here and you will find that the NAVTEQ website is not very helpful. You will also find that NAVTEQ says you should get your updates from Porsche -- and Porsche says you should get your updates from NAVTEQ. For my money I think you should request and updates from Porsche since you (and I paid them the money for the car in the first place).
  10. I have not heard of more than one failure of the re-designed switch/lock assembly. But I think you need to remember the original switch problems didn't show up for 3-5 years - so the redesigned switch/lock should be about reaching that soon.
  11. I guess that would depend on how much lower your car is. Yes, the 997GT3 ducts are longer rather deeper - like the racing ducts. For most DE's I doubt you would see a difference (IMHO).
  12. I get to them as soon as I can and in 99.997% of the cases within 24 hours. In this case about 3 hours...
  13. Sounds about right to me - especially considering most if the video you are in a garage.
  14. You can find any "recall" at NHTSA - Office of Defects Investigation. All the "Workshop Campaigns" are in the TSB section(s) and both their TSB Number and Tile start with "W".
  15. Regular Members can see a list of TSBs - but Contributing Members can view the TSBs online here. If you would like to find out more about the benefits of becoming a Contributing Member have a look at How to become a Contributing Member.
  16. Both are Porsche System Testers. They are used to check various car functions using the OBD II port located under your dash. A PST2 (older model) and the PIWIS (newer model) are used to test for faults, clear fault codes, program systems (i.e. alarm, keys, instrument cluster, DME, etc., etc.). They also have the capability to test individual systems in your car like lights, fans, windows, heater controls, etc. etc.. Many independent shops have a PST2 and a few have the PIWIS tester. Before you run out and buy one for yourself you should be aware that the current prices are (about) $3600 for a used PST2 and $18,000 (per year) for a PIWIS tester. Still some programming functions (like programming keys, and alarms) still require a special access code that can only be obtained from Porsche. Even dealers have to do this and I am sure it is for legal and safety concerns.
  17. These are not plug n' play - each cluster is coded for the car it is in. You will need a PST2 or PIWIS tester to transfer your settings or manually set the features in the cluster to match your car.
  18. I run 32 front and 36 rear. I look for the best handling for my type of driving. I do not worry about wear. I don't think there is anything you can do to get even wear with these cars and the amount of negative camber you need for performance. The rear tires will wear faster -- 911's have been this way since the mid 80's.
  19. There is a 9 page TSB for various dash noises. Most of the fixes involve felt tape, foam padded tape and teflon tape.
  20. This particular one is the headlight connection.
  21. Item 7 in the diagram in this thread. Be careful not to damage the paper gasket (item 4).
  22. Sounds like two problems to me. One is that if the car runs better (other than idle) with the MAF disconnected then you likely need a new MAF. The idle condition on your MY99 C2 could be caused by carbon buildup on the throttle butterfly and the Idle Control Valve (ICV). Clean both with some carb/fuel injector cleaner. Make sure the ICV moves freely - if not it will need to be replaced too.
  23. If they are really dirty or never been cleaned then I suggest you remove the front bumper and then clean the AC condensers and radiators behind them. Removing the front bumper is less than a 15 minute job.
  24. I would start looking for poor/corroded ground connections. They are fairly common in those cars as they age.
  25. In most cases the sunroof frame needs to come out.
