  1. http://www.renntech.org/forums/index.php?s...ost&p=47193 Alos, did you see section 5 (Noise in area 5 – Creaking and/or rattling noises on the panel for passenger’s airbag.) of TSB 1/00 7018 -- dated June 30 2000?
  2. First if your battery is over 4 or 5 years old - replace it as it likely no longer taking a charge. If you are positive your battery is good then you need to put an amp meter inline with the battery. Then remove fuses one at a time until you find the fuse circuit that is drawing all of the power. Normally a 996 draws about 40-60ma (as I recall). Once you find the circuit where the drain is then it should be fairly easy to trace down the component.
  3. The MY2002 Tech Book says: Since they now have about 5 years experience on the "no change fuel filter" -- it must be working...
  4. Then you are going to need to go to a dealer or directly to Becker. Last time I checked Becker charges $35 - sometimes dealers do it for free and sometimes they charge.
  5. No sometimes my program does not work. One more... try 3363
  6. Did you check the separate headlight fuses - there is one for each side.
  7. There is a (15 page) TSB that describes installation for MY2007 and newer cars WITH PCM. I do not know if that means you can not install it in a MY06 car. You might need a PCM upgrade to install it.
  8. The EVAP canister in a a 997 is quite different than a 996. It is a rectangular box that sits in the trunk. But the functions are the same. If you disconnect it from it's mounting screws and then disconnect the electrical and vapor lines then it should come right out.
  9. If the battery is over 4 years old replace it. Have the battery tested and charged. If the problem continues I would suspect the ignition switch is bad.
  10. Exact Model? Model Year? Country?
  11. I would get it to a shop with a PST2 or PIWIS tester and have them test the sending unit circuit.
  12. More likely your code reader? What are you using?
  13. These items have been available here to Contributing Members for some time.
  14. Please try using our search feature as this has been covered before.
  15. Please try using our search feature as these have been covered before.
  16. WKD.924.021.87 Owners Manual -- $62.53 (Canadian) at your dealer Try PMing member Porschelibrarian - he may be able to find a 924 service manual.
  17. TSBs sometimes cover accessory installations (like Sport Exhaust, CDC-4 CD Changer, Telephone, etc., etc.) - but there is not a TSB on the steering wheel. Perhaps that is because it is covered in the service manual. There is nothing special about removing the steering wheel - once the airbag is safely removed.
  18. Sorry, but I have no idea what you are looking for. Do you want an owners manual, a service manual? or a schematic or ?
  19. We have added and/or updated TSBs in the following categories today (36 total): Boxster (987) - 7 Cayman (987c) - 4 Carrera (997) - 8 Cayenne - 13 GT3 (997) - 1 TT (997) - 3
  20. The bumperettes are held on by clips from the back side of the bumper. You will need to remove the bumper to remove them. What are you going to do with the holes that are left?
  21. What model year do you need a diagram for?
  22. I think it just snaps on the seat frame.
