  1. Does it turn over (starter runs?) but not start? If not, then start with the clutch interlock switch.
  2. Try 5381 or 5379
  3. Where do you live and what type of fuel are you using?
  4. I sent you your upgrade notice - you need to logout and then log back in.
  5. My car is MY1999. Perhaps Porsche feels that changing a remote key battery is now a "dealer serviceable item". :lol:
  6. The PCM Operators manual is free to download by any member. You can find it in the Porsche owners Manuals section. If you want the installation TSB - then you need to be a Contributing Member to view the TSB. Just click on the Donate link at the top left of any page to become a Contributing Member.
  7. Your car came with strut braces that are the same as the GT3 Cup Car race cars -- I guess I don't see a need for any additional bracing. JMHO.
  8. 1. I would not spray anything on the radiators (or the condensers that sit in front of them). Any oil/grease spray will attract dirt and debris to stick to the cores. 2. Yes, there are a number of mesh type products you can use. The finer the mesh the more air flow you inhibit. Have a look at the racing GT3RS mesh - I would not go with anything smaller than that.
  9. Dir you look in your Owner Manual? - it's covered on page 18 of mine.
  10. They are $110 (for all wiring diagrams per model year) at the Porsche Technical Website. What are you wanting to do?
  11. Just like the photo in the DIY section - through the end.
  12. No problem - I have already moved the posting to the proper area.
  13. The DME will relearn idle in less than 5 minutes. Take it for a test drive - it should be smooth by the time you return - if not then there is some other problem.
  14. Orient Express - You could be right. Test fitting will tell.
  15. An airbag light is a safety issue. You will need the Durametric Software, or a PST2 or a PIWIS tester to reset it. Many independent shops have one or more of these tools. Where are you located?
  16. Have your dealer (or OPC) check to see that you have the latest firmware in your PCM.
  17. Without reading out the fault codes - you are shooting in the dark. Many parts stores will read your codes for free. Have your codes read and report (all of them) back here.
  18. All Boxsters have OBC built in -- it is just not turned on. You need to find a shop with a PST2 or PIWIS tester and have them turn it on. If you want the steering wheel stalk that can be added to - or you can mount a switch on the dash board to change the options.
  19. I think Richard meant 986.606.125.01 is the correct MAF for 3.6 liter engines.
  20. The trim at the lower (both sides) of the center console are located with push in clips and can be prised off easily (no screws) To remove the gear shifter trim see here http://www.renntech.org/forums/index.php?s...mp;hl=gearstick Thanks for the reply, I see that the pictures are from a 986, and I thought that it would be the same for a 987, BUT when I tried to pull up just like is shown in the pictures I gave up just before I thought I had reached the breaking pressure to snap off something! I also tried pulling on the trim that runs along each side of the center console at the front and met with the same results, it wouldn't let go?! I figure there is a method to all of this and when done coreectly they may just 'pop-off', but I don't really want to head down to the dealer to buy someting that I broke by pulling in the wrong place... This is when an exploded drawing would be invaluable! For a 987/987c 3. Pull up and off.
