  1. Was it really oil or carbon? If it was oil you have another problem. If it was carbon then just clean everything and if the ICV does not move freely it will need to be replaced.
  2. I think this will depend on the version of PCM (hardware) that you currently have. In some cases the hardware has to be changed out because it can not be updated. In some cases all you need is the DVD.
  3. I believe that is a 968 emblem (944.559.220.03.70C logo in rally black) - re-arranged.
  4. In some cases you will also meed a firmware upgrade that can only be done with a Porsche PIWIS tester by your OPC. Many dealers will do the firmware upgrade for free since the car is under warranty.
  5. If you don't know your radio code then get us the last four digits of the radio serial number and we will see if we can help.
  6. No, D9 is the amp fuse. I'd start checking cables - if someone moved stuff behind the dash then it is pretty easy to accidentally detach a cable.
  7. If you have an amp did you check that fuse too? Perhaps a cable is unplugged?
  8. The toe can be correct and the steering still be off. It is a case of turning each tie rod equal amounts to get the proper toe - without misaligning the steering wheel.
  9. eshuber is correct - just press it back in.
  10. Fuel injection systems do not tolerate water like old carburetors did. I've seen cars make it home and then not start at all the next day - water in the gas.
  11. Hmm... so your problem was within one of a fill up?
  12. Just so we can rule it our... when did you last fill up with gas?
  13. Perhaps we can find a member with a PST2 or Durametric Software to see what the actual values of some of the sensors are.
  14. I couldn't find a section on that in the 993 service manual. Perhaps this parts diagram will help.
  15. It's pretty simple. Once the two screws are out you lift the ash tray out and remove wire from the light and press the switches out (remember which one goes on which side). Then to install put the switches in one at a time making sure that they snap into place. Since there is no light in the new non-smoker tray you just leave the wire from the ash tray light unplugged (but out of the way). Put the two screws in and the rubber mat and you are done.
  16. I would start by looking for a loose front swaybar mounts. Those are fairly common. Next I would check the shock tower bolts.
  17. In the US OPC is the dealership. The dealer can reset the counter and erase the message (with their PIWIS tester).
  18. Hmm... never noticed that before. Likely a misprint because I know folks have ordered this kit and gotten everything they need.
  19. Yes, I don't see this as useful Porsche content - so I am closing this thread.
  20. That is the correct part number. Since it is a "kit" there is always the chance that one or parts is holding up the order. Here is itemized list:
  21. For folks wanting to do this... Chuck Jones and I did the latch replacement today and Chuck shot a bunch of pictures. I will post a DIY with pics soon. Nothing really to hard here. The canister comes out with a little wiggling (disconnect the vent and electrical lines first). The actuator itself is a bit tough to get to and you will need a really short T-20 Torx head to loosen the two screws. I say loosen because that is all you need to do to remove the part - it sits in two "U" shaped slots. BTW... Chuck's alarm problem was not the actuator - he has a bad front hood microswitch (thanks to my trusty PST).
  22. I'm pretty sure it is the same radiator but in the RS the radiator is tilted the opposite direction and the ducts are different.
  23. Ah... If you look at the $247 package it reads "Enthusiast Package This package is designed for the Porsche enthusiast that works on there own car. It offers all of the great features as our professional kit but will only work on up to 3 cars." My guess is that too many shops were buying the software and using it - while Durametric got no additional income. Or you bought it and use it on all your friends cars - then they don't need to buy it. Seems fair to me. They have an excellent product - they deserve the money they make.
  24. Then you likely have the wrong type of battery. All batteries vent gases (acid gas). Since this is inside your trunk area you really want a battery with an external vent connection (and that tube connected). http://www.renntech.org/forums/index.php?s...ost&p=14446 I cannot find the vent hole for Interstate MTP-91 - Mega-Tron Plus. http://www.interstatebatteries.com/estore/...nk%7C1&js=1 I have used the battery for 2 months. Am I asking for trouble for continuing to use it? It is right in the center - just like the others. It is that small oval opening. You will need to get the short tube that fits the oval and connect it to your clear tube. I think all of these batteries seem to be made by Johnson Controls.
