  1. Well, you will need to get under the car (safely) and inspect the connector/wiring and repair it if needed.
  2. I would clean the wiring connector and inspect it for damage.
  3. IMHO 10 miles is not enough. When I added my third radiator I bleed the system and topped up the coolant tank daily for over 1 week. Then it stabilized and I haven't added anything since.
  4. Just because your car was built with the older version of the seal does not mean it will leak. Still it would be wise to have your dealer check for leaks before your warranty runs out. If they find any be sure it is noted on the repair order - so you proof the issue was there when you were still under warranty. But, like I said it may never leak - only a small percentage ever do.
  5. I would reverse step 2 and 3. The key activates the airbag circuit - even when the car is off. So, you want to disconnect the battery first.
  6. Yes, you can use the Porsche 17 mm spacers (on the rear only) with those wheels.
  7. You can always look things up in the Glossary... http://www.renntech.org/forums/index.php?a...;id=1&st=45
  8. A MY2000 does not have an idle control valve it is an egas car. I would likely start by looking for air leaks and also to see if the throttle butterfly is "carboned-up" and needs cleaning.
  9. Fault 49 Belt buckle, passenger
  10. I think you need someone to run the tests on your O2 sensors.
  11. 996? I have a 986! I dont recall seeing a DME Tests section - but I'll have a look tonight. Cheers, Jules You posted in the 996 forum. Just go to the 986 section - it has the same test.
  12. US car? If so, under the dash to left of the steering wheel.
  13. Go to your model (996) then to DME. Once you have the DME tests scroll down to Short Test.
  14. No, power and ground come in on the green connector (several pins).
  15. Have you checked fuse B10? Also make sure all the cable to the back of the cluster are properly plugged in and locked.
  16. From what I can tell it pretty much has to be a problem in the clutch master cylinder or the accumulator.
  17. Not really - just don't crack the plastic.
  18. In a TT the brake fluid and clutch fluid are completely seperate - one can not affect the other. In a TT the clutch shares hydraulic fluid (Pentosin) with the power steering - so the problem you are seeing could be with either the clutch or power steering system. Is anyone turning the steering wheel or actuating the clutch while the engine is off? As I mentioned above - this would cause the fluid level to rise (per the service manual).
  19. The sticker should be on the drivers door just below the lock mechanism.
  20. A little early for a sensor failure but I would get someone with an OBD II tool that can graph and show the O2 sensors voltage. My guess is that one or more of the sensors is not working like it should. Also, are you sure your CEL light is not removed or burn't out. Does it come on when you turn the key to the on position?
  21. On the drivers door is tag - it has your build date on it. Check the date against the date I provided in the post above. If it is a newer build than that date then you have the new seal.
  22. Bumper cover? Just normal hand tools - screwdrivers, hand wrenches, etc.
  23. How many Km on the car? You may need new O2 sensors as they degrade over there lifespan. For US cars the PST2 has a test - if you don't get 5 happy faces then you won't pass emissions. I don't think RoW cars have the vent test.
  24. The best list I know of is here
