  1. Porsche now approves of 0W-40 or 5W-40 synthetic oils - so either is fine.
  2. Well, if you are lucky you can get to it from underneath (like I've seen several mechanics do). If not then - it is a lot more work to take the wheel off and partially remove the wheel liner.
  3. Loren
    mk1 flywheel
    "-01" means years prior to MY01 - which would include MY99 through MY01. I did not say I don't believe you. I am trying to understand what PET says - because it is usually right.
  4. Here is what I would do. Clear the codes and see what if any come back. I suspect the seatbelt buckle (airbag light) will come back. You can search the forum here for your options to fix that problem.
  5. Loren
    mk1 flywheel
    That image is from the RoW side of PET - and it is only one month old.
  6. On a US car it should be on the passenger side - and there should not be a reason to jack it up. Some mechanics have a small grab hook to grab the cable and then just pull it to open the trunk.
  7. I guess I still think you need to get to the battery and change it out. The emergency release is all mechanical so it should still work.
  8. Ok, I misunderstood you. You can open the door but you can't get tin the front trunk - right. If so, use the emergency release cable behind the right front wheel well liner.
  9. Use the mechanical part of the key in the mechanical door lock.
  10. If your car has been sitting longer than 5 days then you need to open it with the mechanical key. See your owners manual for more detail.
  11. Loren
    mk1 flywheel
    Please explain your conclusion? M002 - 911 Carrera RS Road version M003 - 911 Carrera RS Clubsport version M004 - 911 Carrera RS Street version
  12. ...or Sunset Imports (Porsche Parts at Dealer Cost) ;)
  13. You can download and check the owners manual here.
  14. 996.341.117.90 Left GT3 (mk1) brake duct 996.341.118.90 Right GT3 (mk1) brake duct MSRP -- $128.97 (each)
  15. Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio. Write it down and post it here.
  16. How can you tell if you have it. I have a 99 c2 but my option sticker is gone. last month i was changing my triptonic atf and the mechanic told me i have a lsd . Can any one tell me how to check to make sure. I do not have TC. Does any of your paperwork have the transmission model number? Should start with G96...
  17. P1124 Oxygen Sensing Adaptation Area 1 (Cylinders 1 - 3) - Rich Threshold P1126 Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Rich Threshold These codes mean that is too lean. That is, the DME can make the mixture rich enough to compensate for a lean condition. Potential causes are: - Intake air system leaking. - Fuel pressure too low. - Volume supply of fuel pump too low. - Fuel injectors fouled.
  18. Which ones? There are 3 different part numbers for 996 GT3 brake ducts including the GT3 RS ducts.
  19. Unlike most US manufacturers Porsche (as do many other European automakers) does not give out any information - you have to dig for it yourself. Even the EPA had to threaten them to get them to release OBD II codes to the public. Read this article for: Cracking_The_European_Data_Safe.pdf
  20. Sorry, that is not a good part number. It is now 996.504.981.01.G2X -- MSRP $92.03 :eek:
  21. I sent you a PM so that you can check out the wiring.
  22. The car - it sounds like a bad battery. You might want to have it tested. 2nd would be the ignition switch - sometimes wiggling it makes a difference. If you can wiggle it and make it work you need a new ignition switch.
  23. Please do not double post. Your question has already been answered here.
  24. How old is your battery?
