  1. Loren
    mk1 flywheel
    There is only one PET and it is updated monthly - to all dealers worldwide.
  2. To the right of the battery, on the firewall, is a rubber plug. Cut an X in it and pass the wires through.
  3. The GPS antenna is Porsche part number 996.642.206.00. I show a US MSRP of 93.48 USD. Make sure you get the cable too. You can probably get a CD on eBay or from NAVTEQ. The security code will have to come from Becker. You will be asked for the serial number of the unit and also likely for some proof of ownership.
  4. It sounds like you have a wire in the wrong place. Or, the wrong relay in the wrong position.
  5. Have you checked fuses B9 and E9?
  6. Perhaps you are confusing the bumper pieces with the underbody covers?
  7. They are all the same MY99-MY05.
  8. The underbody covers don't change whether you have an aerokit or not.
  9. The image would imply that but I see nothing in the parts list that would validate that. Best ask your ordering dealer.
  10. 996.111.108.00 Clamp -- MSRP $11.96 each (as of July 2007)
  11. Did you check the main fuse and the one behind the radio?
  12. As I recall a 1/8 inch drill bit in the center of the rivet. Keep the drill straight. You will have holes to plug up.
  13. Yup, you will need to drill out the rivets.
  14. Ok, lets try 4547 or 4549
  15. asphaltguy - where are you located?
  16. Try 2897 or 2899
  17. The best explanation Tool Pants and I have been able to come up with is that it is supposed keep loose items from falling in there and jamming the cables.
  18. Your serial number does not look right. Did you follow the procedure above to ge the serial number to display?
  19. I think you have to wait 1 hour.
  20. http://www.renntech.org/forums/index.php?a...ODE=03&id=9
  21. There is no flaming allowed here - please re-read the board Rules/Guidelines. So, folks, get this thread back on topic - or I will close it.
  22. As long as you have the standard (not short shifter) - there is a tool that holds the gearshift in the proper position and you just drop the cables into the clamps and lock them. Most Porsche shops have the alignment tool - and I think you can buy it too.
  23. Other than the shift knob there is no difference in the (in car) linkage).
