  1. Have a look at the Maintenance Checklists here. Do you have any service records so that you know the 30,000 mile major service was done. I wouldn't touch any seal that is not leaking. A common problem with the rear suspension is loose swaybar mounts.
  2. You can likely get it pretty clean by holding the butterfly open and spraying behind it. I like to remove the throttle body because it is not hat hard and then you can see the back side of the butterfly (without forcing it open) and make sure that the small idle holes at the edges are clean.
  3. One thing you might try is a top calibration. This is done with a PST2 or PIWIS and resets the top transmissions on each side so they move evenly (at least that is what we think it does). I did this once for a guy with a MY00 Cab and seemed to solve his problem. The assumption here is that you have checked to see that nothing is bent or broken in the top hardware.
  4. Loren
    mk1 flywheel
    I think you folks are losing site of the original posters question - "Did the mk1 come with a single mass flywheel?" and I think we have shown here the answer is no and yes. No in the standard version and yes in the ClubSport version. Is this not true?
  5. Loren
    mk1 flywheel
    The Cup flywheel is 964.102.239.80. The one listed above for ClubSport (M003 and M004) cars is 964.102.239.31.
  6. Have a look at TSB 5/99 2015 Fuel Tank Hose Modification -- dated 8-12-1999. It may pertain to your car too.
  7. For the radio try 4275 or 4273
  8. It will depend on the size of your hand - some folks can reach up from underneath and grab it and some folks take one of the plastic rivets out to slip their hand in (that would be me). A CDR-23 is a MOST bus radio will only work in a MY03 and newer car.
  9. Bad news - those control motors are all controlled through the Climatronic. I think you should re-check your connections and if they are okay then your Climatronic is likely bad.
  10. There is likely nothing wrong with your fan. This question has been answered many many times here (please try a search next time). http://www.renntech.org/forums/index.php?s...post&p=1530
  11. If you want me to look at the schematic - then I need to know model and model year please (as requested at the top of this forum).
  12. M9670-644 is a 309 KW (or about 415 HP).
  13. You should not remove the oil cap with the engine running. The oil vapor system is part of the US emissions requirement. Your car may come back to normal after a few drive cycles or you can force it to re-learn by disconnecting the battery for a short time. Keep your radio handy if you decide to disconnect the battery.
  14. I would start with cleaning the front radiators - especially if it has never been done. Just remove the front bumper and clean the AC condensers and the radiators behind them. How to Remove the Front Bumper
  15. Part numbers change all the time and unless there was another reason to update the TSB Porsche rarely updates them for part number changes. I guess they assume their parts system will tell you the new part number when you place an order (which it usually does).
  16. Do you have a 996TT Service Manual? The procedure is about 51 steps and several pages.
  17. 5AT Cork was a color for 1979.
  18. You might talk a dealer into giving you the code or you can pay Becker $35 for the code.
  19. If your VIN is below these numbers you likely need a new striker (per TSB 4/99 5726 New Door Latch Striker). 99 _YS 62 0622 Coupe 99 _YS 65 1073 Cabriolet
  20. Th emergency release cable is behind the right front wheel well liner. It has been covered many times here. You just need to reach in there and pull the cable.
  21. Those are Aerokit II sideskirts - as they should be for your MY car.
  22. 1. Try retraining the window. Hold the button down until the window is all the way down then continue hoding it for another 10 seconds. Do the same after raising the window. 2. If you get a honk it is because an alarm zone is still open. Common causes are: 3rd party radio, broken microswitch in the center console, broken microswitch in the front (or rear) trunk. You need to find a shop with the Durametric Software, a PST2, or PIWIS tester and a simple test will tell you exactly where the open zone is. 3. The seats are not the airbag circuit - the seatbelt buckles are. The same software above can tell you where the problem is with your airbag light too.
  23. Try 6944 or 6946
  24. If they are factory then they should be Aerokit II sideskirts.
