  1. We have added and/or updated TSBs in the following categories today (9 total): Cayenne - 4 Cayenne (Gen 2 as of MY08) - 4 TT (996) - 1
  2. You open the bleed valve when there has been air introduced into the system - like after a hose change or a radiator replacement. It is not intended for a coolant flush procedure. For a coolant flush the new coolant needs to be drawn into the engine/system using a vacuum device. This is only way to assure that you don't get air trapped in the system somewhere when refilling or flushing the complete system.
  3. It has a membrane so it is in fact a 1 way valve. Pressure normally pushes the valve open and air escapes through the membrane but not liquid. Cup cars run with the valve open all the time.
  4. On 9x6 series the adjustments are all Torx screws inside the door panel.
  5. There are tiny air bypass ports near the butterfly (or in MY99 C2 an idle control valve) when these get gummed up with carbon deposits they can affect the idle. I usually run a bottle of Chevron Techroline through my car about every 3,000 miles - that seems to keep the carbon build at bay.
  6. Did they replace either of the front headlight leveling sensors? If so the controller will need to be recalibrated using a PIWIS tester.
  7. Try 993.701.422.03 (for US stickers)
  8. If you are sure the spark plugs/coils are good then you need to start looking at other possible causes of the misfires. Such as a bad flywheel sensor, or bad cam sensor.
  9. P1313 Misfire, Cylinder 1, Emission Relevant P1314 Misfire, Cylinder 2, Emission Relevant P1316 Misfire, Cylinder 4, Emission Relevant P1318 Misfire, Cylinder 6, Emission Relevant P1319 Misfire, Emission Relevant Most likely causes: - Fouled, faulty or incorrect - Contact resistance - Loose contacts Have you changed the spark plugs recently? Correct spark plugs? You should check the continuity of the flywheel sensor. Check for cracked ignition coils.
  10. The oil change is the same as the Carrera here.
  11. Can you double check the part numbers?
  12. Did you take the two Torx screws out of the AC condensers and clean the radiator behind them?
  13. Those are not TT style bummperettes. Those alook like MY02 and newer Carrera bumperettes. Your bumper would need the slots and the support bracket (that holds them in place) to use these bumperettes.
  14. Sorry, my misunderstanding. Let me make sure I understand what you want to do... You want to put Boxster (at leaset the part number implies Boxster) sideskirts on a MY99 Carrera? Those are not good numbers from what I can research (for either a Boxster or Carrera). If they started with 996 they would be correct for a MY99 to MY01 Carrera.
  15. Those are the correct numbers from the 2000 TSB (actually they have a G2X appended to the end of the number signifying that they come unpainted). Porsche later updated the parts (and part numbers) to 986.559.980.01.G2X and 986.559.981.01.G2X. I do not know what changed - or if it was just a vendor change. Bottom line - they should work fine. See TSB 3/00 6315 Installing Cup Aerokit -- dated 7-21-00
  16. P1115 Oxygen Sensor Heating Ahead of TWC, Bank 1 – Above Limit I would clean and check the connector on that sensor first - then reset the CEL and see if it comes back. If it does then replace it.
  17. I sent you a PM.
  18. I agree it seems strange that the US government forces car makers to give emission warranties but not safety item warranties. This can certainly be done by some that is used to working on electrical connections and soldering. Some folks have gotten by just replacing the faulting buckle and not doing anything else. Porsche's TSB fix is intended to stop any future issues.
  19. Have you tried using Scour's VIN Decoder here? Scouser's VIN Decoder
  20. Correct that is normal for a fixed wing (correctly wired) - even the factory wings do that).
  21. No the MAF are the same for all 997's (986.606.125.01).
