  1. Why wouldn't you buy a Porsche with a Tiptronic? Have you ever driven one? Did you know the 997TT with a Tiptronic is faster than the 6 speed (0-100)?
  2. I would remove the covers on the underside and check for things bent or damaged. The cover just unscrew as I recall.
  3. Without the fault code(s) everything is just a guess. Go to an Autoszone (or other auto parts store) and get your codes read. Write them down and report them back here.
  4. That is pretty good jolt - I would get the car up on a lift and look for more underside damage. "After triggering of the airbag unit on the passengers side (parts that must be replaced): - Airbag unit, passenger's side - Triggering unit after the third time the airbag is triggered" Remember that is also likely recorded in the DME - so you might want to document the "accident".
  5. Check for a corroded ground wire in the rear trunk.
  6. Try 2672 or 2674
  7. Did anyone ever change the dials/faceplate on the cluster? You can screwup a gauge that way. The cluster can be a problem - you should check with Sunset Imports (Porsche Parts at Dealer Cost) for a better price.
  8. Are you sure the calibration was done correctly? You have to take all the fuel out of the tank - then put in a measured amount. Then do the calibration. See How to become a Contributing Member at the top of any forum
  9. Or... you could have just used the "Glossary of Technical Terms" on the Quick Menu ;)
  10. Learn something new everyday switch on hold down TP for 10 seconds. would'nt have found it without this forum many thanks.Could'nt find how to do it in the radio manual that came with the car. Becker 1 type 4467 Serial no Y5026921 24/99 Try 6971 or 6973
  11. You are joking right? Jeez I hope that wasn't a dealer...
  12. How to get your radio to display the serial number has been covered here many times. As well you can download the manual here. Please do a search...
  13. Is that your VIN or radio serial number? If it is your radio serial number then try 8893 or 8895
  14. See if your car came with Option 1D6. That is the towing/trailer hitch option and should have included everything except the ball.
  15. Yes, a good number of MY99, 00, and 01 cars had their radio replaced for peeling buttons. Mine was replaced too - I should throw away my old radio code card - it just confuses me when I need to use the code.
  16. Water Pump Replacement See Robin's DIY at his site: 996 Water pump replacement/ Alternate PDF file (if link does not work) 996_water_pump_replacement_procedure.pdf 996_water_pump_replacement_procedure.pdf Author Loren Category Carrera (996) - Common Fixes and Repairs Submitted 09/03/2007 03:18 PM
  17. See Robin's DIY at his site: 996 Water pump replacement/ Alternate PDF file (if link does not work) 996_water_pump_replacement_procedure.pdf 996_water_pump_replacement_procedure.pdf
  18. We need to know your model and model of your car - plus the radio model (CR-210, CDR-220, CDR-23, etc.) to help...
  19. Many times a whistling sound heard at speed is a misalignment of the front bumper cover and the front hood. To find out for sure put a piece of tape across the hood and bumper seam and see if it still happens.
  20. Book time is 240 TU or 4 hours. "Book time" is usually slightly overstated.
  21. Todd, You are correct the pistons only got replaced on the 3.4 liter X51 kit. The 3.6 already has the same pistions.
  22. No special clutch for an X51 package - I was just stating that because you don't want to put a worn clutch in with a shiny new (more powerful) engine. Also, he is putting this in a Boxster.
  23. Try 4672 or 4674
