  1. Be happy the pulley failure didn't take out the alternator - many times it does. Go through a few starts and stops and see if the ABS light clears. I have seen that before and sometimes you just need a few drive cycles.
  2. Unless you have a wiring harness problem - it looks like the DME.
  3. No relay so it is either the switch or heater itself. Short term you can pull fuse E4 and or A6.
  4. I suspect that if you replace the whole bumper it will work fine. My comments were about using the newer part on an old bumper (unless I misunderstood you).
  5. Only if the DME will allow a re-program - then it is likely still not a long term solution. The problem is usually not software - but hardware.
  6. Many times a PSM and ABS light on at the same time mean that either the brake light switch is out or the MAF is bad. Testing the brake switch is easy - just get someone to stand behind the car and tell you if they come on when the brake is applied. You need to take the car to an auto parts store (like Autozone) and get your codes read for free. Write down the code(s) (all of them) and report back here.
  7. From what you describe it could still be a bad alarm/central locking/immobilizer control unit. You need to find a shop with a PST2 or PIWIS tester.
  8. http://www.renntech.org/forums/index.php?showtopic=185
  9. If it is wet under the left hand seat then your alarm/central locking/immobilizer control unit is likely bad.
  10. Scouser has updated his excellent VIN Decoder. The VIN Decoder is here. Many thanks to Scouser for his continued efforts, work, and updates to this fine tool! :clapping:
  11. Have your cluster light sensor tested - it may be going bad.
  12. Ok, I am very confused here. On a MY01 Boxster the brake lights do not go through a relay. On a MY01 Boxster the only thing on fuse B7 besides the brake lights is cruise control - neither of which run up the A pillar. Perhaps something else is shorting out the brake light wires? Exactly what fuse blew?
  13. Please define "worth it". Everything there will you at best 10 RWHP and a better sound.
  14. Do a search here - we have covered how to remove the cluster and replace the bulbs.
  15. MY99-01 are Litronics. MY02-05 are Bi-Xenon. Mechanically they are very different.
  16. I have graphite grey in my car and it matches fine.
  17. Have a look at TSB 7/02 1001 Option X51 - Increased Engine Performance -- dated Dec 6, 2002
  18. The only change for MY01 was "In order to reduce the level of chain noise the intermediate-shaft drive will be converted from a roller-type chain to a tooth-type chain in model year 2001. Because of this the crankshaft, intermediate shaft and corresponding chain tensioner will all be modified". There were also some OBD II changes in MY01 for the (European) EOBD and the EURO 3 exhaust emission standards. I do not have the changes for MY00 - I have not been able to get my hands on a MY00 Service Information book.
  19. The stock dyno graph is in your Owner's Manual -- albeit averaged.
  20. Just a thought and don't crucify me, but has anybody tried sticking a lawn vac/blower nozzle up in there a bit to try to suck all that crap out? With the small nozzle on my Toro it will pretty much suck the chrome off of a trailer hitch if you position it right, or be as delicate as a toothbrush if thats what you need. Yes, and problem is it does not get much of it.
  21. That center cover (and the bumper it fits) changed in MY03 - I do not know if it will fit an older car.
  22. In a Porsche Sport Exhaust you apply power to a solenoid that actuates the vacuum valve on the muffler. A vacuum is required to pull a flap in the muffler to make it quiet. So, if the mufflers are not connected to the vacuum line or the electronics are not hooked up then the muffler are always open (loud).
  23. http://www.renntech.org/forums/index.php?s...ost&p=80894
