  1. Try 5190 or 5192
  2. Folks please do not start a new thread when one already exists. Lost Radio Code Thread
  3. Folks please do not start a new thread when one already exists. Lost Radio Code Thread
  4. Hmm... the parts list says they are all the same.
  5. That is B in the diagram - for the front transaxle.
  6. A is the inspection/fill plug. B is the drain plug. Fill until it at the inspection plug level (just before it overflows).
  7. If you have replaced the idle control valve and the throttle position sensor and cleaned the throttle body then you likely have an intake leak somewhere. You are only going to see that with an OBD II tool that can show air flow and TRA and FRA. Still it might not hurt to look for any pending codes.
  8. Looks like the MAF sensor connector to me.
  9. Try 1574 or 1576
  10. The Becker keys also work on many Mercedes.
  11. Bank 1 is the left side of the car (on a Carrera) cylinders 1-3. I have no idea what your readings should be with a supercharger. From the fault codes I would look for bad connections on the O2 sensor before the cat on the left hand side. Clean the connections and reset the codes and see if they come back. If the same codes come back - that O2 sensor is likely bad.
  12. P0134 Oxygen Sensor Ahead of TWC, Bank 1 – Interruption of Signal Possible causes: Open circuit in signal wire or ground wire Oxygen sensor heating not functioning Output stage in DME control module faulty Internal resistance too high Check: – Wiring harness – Oxygen sensor – DME control module P1115 Oxygen Sensor Heating Ahead of TWC, Bank 1 – Above Limit Heating current too high – Heating resistance too low – Short to B+ Heating current too low – Short to ground – Corrosion in connector – Break in wiring except for a few wires Open circuit – Break in wiring – Heating resistance too great Internal resistance of oxygen sensor too high – Open circuit in sensor line – Oxygen sensor
  13. http://www.renntech.org/forums/index.php?showtopic=2995
  14. The are test results using a PST2. A PIWIS can do the same test. You just get a shop to plug it in and then cover and shine a light at the cluster. The percent change should be as shown above. If it does not change then you have a bad sensor.
  15. P0491 Secondary Air Injection System, Bank 1 - Insufficient Flow P0492 Secondary Air Injection System, Bank 2 - Insufficient Flow Possible cause of fault - Electrical fault in power supply or line between relay and secondary air injection pump - Secondary air injection pump relay mechanically faulty - Mechanical fault in electrical secondary air valve - Pneumatic secondary air valve faulty/sluggish - Electrical fault in secondary air injection pump - Mechanical fault in secondary air injection pump or secondary air injection pump blocked - Vacuum system leaking - Air hose to secondary air injection pump slipped off or constricted
  16. According to the parts list the GT3 and GT3 RS use the same motor mounts.
  17. :welcome: Beautiful car - Seal Grey?
  18. The folks at Sunset Imports (Porsche Parts at Dealer Cost) just sent me this hot item... Super Sale 98-04 Boxster REAR SPEAKER KIT fits cars with rear storage box Reg $326.78 Now $129.86 Just click on Porsche Parts at Dealer Cost
  19. In series - so you disconnect the battery and put the meter in-line.
  20. There is a horn at the front left and front right near the fog lights. The front bumper will need to be removed.
  21. I use a current meter at the battery.
  22. Depending on options about 40-60 ma.
  23. That is my point - if you have a PSE (Porsche parts) then it defaults to open on the time. No, I did not make my sport exhaust I have a factory PSE.
  24. I do not know of any US law that would require the switch. The law here only requires it to be below a certain db level - and that is only in some states. My PSE did not trigger the noise sensors at Laguna Seca - and they are the tightest track I know of. Except for a few professional races per year you have to run "street legal" db levels. If you wire the flaps other than what they are as default (which IS open) then the PSE will always be quiet. Why would you do that? The PSE sounds like a stock exhaust in quiet mode.
