  1. It depends - if it is a lower hose you might get lucky and just need to remove the liner. If it is an upper hose then you will need to remove the front bumper and likely loosen the radiator mounts to get to the (upper) hose.
  2. As long as the prescribed service is performed they can not void your warranty. http://www.semasan.com/main/main.aspx?id=60128
  3. The brake light switch is on the brake pedal. If the system integrity has been kept intact then you should be fine. The coolant is "Lifetime" coolant per Porsche. Do not mix coolants with the Porsche coolant.
  4. :welcome: Most dealers don't even hook up a PST2 (or PIWIS tester) when changing the brake fluid. Many good independent shops have a PST2 or PIWIS tester (PIWIS is a newer version). A few of us have spent the several thousand dollars to have one too. Common opinion is that you do not need to do that unless large amounts of air have gotten into the system. I have a PST2 and I do not bleed the ABS every time.
  5. It's cover quite well in your Owners Manual - have you looked there?
  6. P0430 TWC Conversion, Bank 2 – Above Limit Potential causes: – Catalytic converter In the case of a catalytic converter fault in the Boxster (2.7 liter and 3.2 liter), only the pre-catalytic converter is to be replaced. P0447 EVAP Canister Shutoff Valve (Output Stage) – Open Circuit Potential causes: – Wiring harness – Shutoff valve – DME control module This one could also be a a loose gas cap or bad o-ring on the gas cap. I would find the leak in the EVAP system and reset the codes. Then see if the cat code comes back.
  7. If the mixture is such that it will damage a cat - then the CEL will flash and the car should not be driven.
  8. No, not without welding and cutting.
  9. There are lots of tips in this thread - please read though it...
  10. Try 0033 or 0031
  11. I think every 996 that I have heard with a light weight flywheel - rattles some at idle.
  12. The oil goes back to the sump the gases go to the intake to be burned.
  13. http://www.renntech.org/forums/index.php?a...&code=dme72 Potential causes have been covered here many many times... please try a search.
  14. Item 7? - rubber lip (left) 996.504.503.02
  15. The mirror comes with a new wiring harness - you need to connect the points on that harness (among many other things). The reverse wire connection point is under the drivers seat. The TSB says a tech should be able to compete the install in 300 TU (time units). 100 TU = 1 hour. Perhaps, this will help you under stand that it is not connect power and you are done.
  16. I think you misunderstand the purpose of the AOS. Per Porsche's 1999 Tech Book: "Since there is no drop between the cylinder heads and oil sump in a Boxer engine, the oil is drawn out of each of the cylinder heads by an oil return pump. Oil Separator The oil drawn off via the return pumps is fed into "swirl pots". In these containers, the oil is centrifuged and defoamed, i.e. gases which the oil has picked up on the way to the lubricating points are removed. This ensures that the oil always has a good consistency which is necessary to guarantee the reliability of the hydraulic valve clearance compensation. Gases could bring about changes in the engine timing which would have an effect on the performance and exhaust-emission behavior of the engine."
  17. Yes, that is the interior auto-dimming upgrade kit. This does nol control the side mirrors unless they are already auto-dimming. You have to run a wire to reverse so it knows to turn off auto-dimming when you back up. You can install the interior auto-dimming without the exterior auto-dimming but not visa-versa.
  18. All TSBs are available to view by Contributing Members. 996.731.511.01.01C Interior mirror (satin black)
  19. My advice is: get a second opinion.
  20. it is not quite that easy - the TSB for installing the Automatic Dimming Rearview Mirror is 5 pages long.
  21. :welcome: Most of the relays are under the dash near the fuse panel. The horn relay is in position 10 here. There are a few relays under the carpet panel near the DME (behind the rear seats). If you are having a horn problem - chances are it is not the relay but a bad horn(s). They are not very good horns and a number of us have replaced them with air horns.
  22. See the post right before yours... Where do I top up the pentosin fluid? does it do into the pump or the rams? The hydraulic cylinder can only be filled in a retracted position. Position the hydraulic cylinder vertically and fill with 5 ml Pentosin (per hydraulic cylinder) using a syringe.
  23. The sensor is in the side of the tank (item 14) - they have been known to go bad.
  24. could be a dirty sensor - could be you have a leak?
  25. Try wiggling the switch while the lights are on. If there is any flickering or other strange occurrences then you likely need a new headlight switch.
