  1. A replacement will vary based on the options your car had (cruise control and OBC). Most of them run about $250 US List price (I'm sue the folks at Sunset Imports (Porsche Parts at Dealer Cost) can do better than that price). Changing one out is the same airbag, steering wheel removal process found in the OBC hack documentation. Might also be an easy time to upgrade to the OBC stalk while you are at it.
  2. 1. C10 Switzerland (emissions for Switzerland) - so check to see if that is legal in your country. 2. No, those should be gen 2 PCCB - which are much better than gen 1. 3. I do not know about other countries - in the US most cars come with 2 primary keys and 1 valet key. I always suggest potential new owners look at all the service/repair records that previous owners and shop will let them look at. If you are getting it from a Porsche dealer then ask for a Porsche CPO.
  3. To get the (best guess) code for your CDR-210 we will need the serial number from your radio. You can get it electronically displayed through the front panel or pull the radio out and read it off the back.
  4. Turbos are the same as a standard TT - intercoolers are the same as GT2.
  5. Try re-training the windows. Hold the button down until the window goes down all the way - hold in final position for 10 seconds. Then do the same for the up motion.
  6. An X50 and GT2 share the shame muffler - that is the only exhaust difference from a standard TT. The manual transmission is also upgraded for X50.
  7. My mistake it is RoW - you are right PET does not ID the kit as RoW but if you look at the individual part numbers they are RoW. It is for a Tip though.
  8. No, an airbag light can only be turned off with the Durametric Software, a PST2 or a PIWIS tester.
  9. How to become a Contributing Member
  10. Unless you are using oil or there are signs of oil fouled plugs I wouldn't worry.
  11. Sorry, I don't recall how many clips. If you have the IR sensor off then you should be able to just pull the defroster trim off.
  12. Could have been spilled when adding oil after an oil change. If your oil level is normal I wouldn't worry about it.
  13. There are several TSBs from Porsche on noises (creaks, buzzing, rattles, etc. etc.). Most of the fixes are as simple as Teflon or felt tape.
  14. Just don't ruin a rotor. Pads are a reasonable $320 per set. Rotors will run you $5400 EACH.
  15. I think the lug nuts on the spacers are the same as most 70-90's model Porsches so those same (McGuard type) locks should work. But if you want to be sure just take a lug nut into a good accessories shop and see if they can match it.
  16. Ride height and stiffness (RoW is lower and stiffer).
  17. Boxster S - US M030 with Tiptronic
  18. :welcome: The late model Carrera 5 spoke wheel came in - Fronts: 7.5 x 18 offset 50 mm 8 x 18 offset 50 mm Rear: 10 x 18 offset 65 mm Chances are the fronts are 8 x18.
  19. Try 5067 or 5065
  20. http://www.renntech.org/forums/index.php?s...ost&p=27954
  21. I don't understand... if the spoiler always works with the manual switch then the hydraulics of the spoiler are fine and don't need anything. Chances are you have an intermittent microswitch on the spoiler.
  22. Sorry, I can not do that - that is copyrighted material.
  23. The 17 mm spacer fit differently than the 5 mm spacers. The 17 mm spacer get put on first with the original wheel bolts. Then you mount the tire on the exposed studs and tighten the log nuts provided. The 5 mm spacer are just screwed on to the wheel hub and then you use the longer (red) wheel bolts. The 5 mm kit looks like this.
  24. The TT service manual does not say one way or the other. The Carrera service manual definitely says no anti-seize. I personally don't see a need a for it and it can cause more problems than help. Here is why I think so... The heads a light alloy and can be easily stripped. The spark plug torque is only 22 ft/lbs. If you are not careful you can get anti-seize on the electrode(s). Most folks think that any lubricant on the threads will affect torque values. On cast iron head engines (and wheel lug nuts) I would use anti-seize but not on light alloy parts.
  25. Not a good design then... Porsche should know better...
