  1. Thanks for the quick reply, Loren. No not bumperplugs, I want to mount the german plates on my 03 Box S. I got a set of German plates with plastic black dealer frames but all I have is the standard "square" looking holes in my bumper. When trying to mount the frames to the car, it seems that I don't have any screw inserts in the square holes, either that or I need different mounting screws. (holes feel empty in bumper) if that makes more sense. Any ideas? Thanks Here is the parts list for a MY03 front bumper (it shows both RoW and US license mounts). You can pick the parts you are missing. my03_front_bumper.pdf
  2. I would suggest that we all hold off on this thread until someone has facts - otherwise it is just speculation. Besides Porsche should be notifying any owners affected.
  3. Here is the pic (poor quality) of the issue in the TSB. This is inside the tank - the fuel pump is at the bottom of the pic.
  4. I would put Lotite on them. When Porsche uses Loctite it is usually for a good reason.
  5. Perhaps a Porsche Workshop Campaign but not a recall. All US "recalls" are found at Office of Defects Investigations (NHTSA)
  6. :welcome: Do you wan the license plates mounts (if so, US or RoW) or... do you want BumperPlugs like this...
  7. Sorry, I don't have a cab so I would just be guessing - I had hoped the diagram would look familiar to you.
  8. They say this but in practice with my car it does not work. I put the key in the door and turn the lock. Immediately the alarm sounds - it sounds as soon as the doors unlock. Note: I have not opened the door at this point. I then have to race to put the key into the ignition and press the button. I'm not sure if once the alarm goes off I can turn it off without putting it into the ignition by just pressing the button. I will try next time.....But simply unlocking it and not opening it doesn't work in my case.... not sure why... Jeff And your car is an RoW car? (I am guessing) They are different alarm systems.
  9. As long as you do not have the performance kit (with the 19" rotors) the 17" wheels will fit fine. (per TSB 10/04 4440 Winter Tires and Wheels -- dated Sep 15, 2004)
  10. From the GT3 Owners Manual: "The remote-control standby function switches off after 5 days If the vehicle is not started or unlocked with the remote control within five days, the remote control standby function is switched off (to prevent discharging of the vehicle battery). 1. In this case, unlock the driver's door with the key at the door lock. Leave the door closed in order to prevent the alarm system from being triggered. 2. Press button 1 on the remote control. The remote control is now activated again."
  11. :welcome: Like many rear engine and mid engine Porsche's the transmission and differential are a shared unit. I think I would start by replacing the gear oil with Porsche approved gear oil. As you say you've owned the car 9 months so unless you know what gear oil he/she put in then it is a possibility. There is a DIY here. Be sure to pay particular attention to the Boxster specific instructions.
  12. You need to read and post here: Lost Radio Code - post your request here
  13. 999.631.036.90 Sorry, I do not know the color temperature.
  14. Um... that is what I gave you... did you see the plug code on the left?
  15. I guess step one would be to get a definitive list of what was replaced. That way we know what we are dealing with. Many of those little problems could likely be solved (re-programming) or troubleshot with a PST2 or PIWIS tester. The two big issues I can think of is the DME (really needs to be a DME 7.8 for a 3.6) and the returnless fuel system used on the 3.6 car and newer. The other guy to ask about this is tholyoak (Todd Holyoak) - he has done several Boxster conversions and recently did a a 3.6 into a Boxster. Now, he chose to use an older DME but I don't remeber if he solved the VarioCam Plus issue. Where are you located?
  16. On some of the early 996's there were problems with hose ties near the fuel filler. This could cause a variety of problems from fuel filling problems to a buzzing noise at the filler. On US/Canada cars there is a fuel return that also returns vapors to the fuel tank - on some of those cars there is a valve that can fail that will cause a similar buzzing sound. Those are the areas I would look at first...
  17. Just send them an email. They are very good about responding.
