  1. Hi Paul, Just catching up on this thread...Mobil 1 is a synthetic oil. I'm a Porsche owner, however, I work with Synpsg too, which is an distributor for Amsoil products. Synthetic oils actually prevent the huge problem that we see in newer cars today relating to sludge. If you would like to read more on sludge, please take a look at the following link: Sludge Problem While I use Amsoil in my Porsches ('03 Boxster, '06 Cayenne, '08 Cayenne S), the only other oil I would use is the factory OEM oil, Mobil 1. The data consistently shows that Amsoil is number one with Mobil 1 a close second...other than that, I trust my investment in vehicles to none of the other brands. Mobil 1 is a great engine oil...Amsoil is not commercialized and in my opinion uses higher quality additives; that's there niche, being the best. I think there could probably much more debate around the quality of an oil filter than that of the industry leading oils. The data is available. Best regards, Bill Not to be argumentative - but if Amsoil is so good why can't you get it approved by Porsche? I think folks that are looking at a $29,000 engine replacement cost (without labor!) are a bit skeptical to use something that the manufacturer has not approved.
  2. Please try our search feature - it works very well. http://www.renntech.org/forums/index.php?s...ost&p=72005
  3. The only place you can get a PCM code is from a dealer/OPC.
  4. Do you have a wiring diagram? We have no idea how these are hooked up...
  5. As I recall there are only U-clips holding the smaller rubber lip.
  6. I think the max boost is adjusted based on other engine variables including exhaust turbine speed. So it could lower or theoretically higher.
  7. I am very sure he is wrong. Using my PST2 - here is a printout from one of my cars in August 17, 2006 and a second printout is from (the same car) today January 3, 2008. If you notice there is a difference of 50.5 hours. This car is in the garage unlocked better than 95% of the time. Considering there are roughly 8760 hours in a year the DME clock could not have continued to run and only recored 50.5 hours.
  8. Engine hours - I don't think so. The air bag hours (clock) continues to run if you leave the key in the ignition.
  9. Yes. Porsche uses smaller wheels for recommended winter wheels 18 x 10 ET 47 mm - so you can fit chains if needed.
  10. http://www.renntech.org/forums/index.php?s...ost&p=64867
  11. Those are considered "Winter Wheels" for a 996TT. Porsche uses smaller wheels for recommended winter wheels 18 x 10 ET 47 mm - so you can fit chains if needed. 996TT summer rear wheels would be 18 x 11 ET 63/65 mm.
  12. The Retail Price Search feature (for our Contributing Members) has been updated to reflect January 2008 pricing for the US (only). We try and update this on a monthly basis as the price lists come available to us. For January 2008 the price lists support - US: 217,862 parts Canada: 209,209 parts (December 2006) Thanks to Contributing Member Porschelibrarian!
  13. No. Any immobilizer change requires reprogramming using a PST2 or PIWIS and your car's unique IPAS code (available only from Porsche).
  14. Read my latest blog entry (Product claims and dynos -- and reality) ...
  15. 996.641.142.00 temperature sensor -- US MSRP $14.07
  16. You can try drying out your immobilizer and praying. If it has shorted out hen you have to get a new one AND have it programmed to your keys and DME.
  17. :welcome: Rector - why? Peter Smith -- shop foreman, 20 plus years as a Porsche tech, PCA Technical Committee, races a 944 in his spare time. A good guy all around (but don't tell him I said so).
  18. 955.107.561.00 Oil filter and o-ring -- US MSRP $14.85 also get a new o-ring for the oil filter bolt (if you open that drain bolt). N 903 054 02 o-ring US MSRP $3.65
  19. You do have to re-login when you go to the Reviews section as it is a different application that treats cookies differently. The main site should work fine with IE7. It does for me.
  20. ... or a cracked tank.
  21. Please have some patience - please allow 24 hours for responses to your questions. Check to see if anything fell into the fan area (under the pollen filter) and if it smells musty then the AC condensor drain may be plugged. If it is the drain then clear the drain and then run the heater as hot as it will go. It might also help to some disinfectant into the area of the heater core.
  22. Cayenne S and Cayenne Turbo are the same procedure. http://www.renntech.org/forums/index.php?s...ost&p=78411
  23. Please try a search here as window problems and causes have been covered many times here.
  24. You need to have your car checked with a PST2 or PIWIS - they can individually test the circuit and likely tell you where the problem is.
  25. There are different part numbers for the Cayenne Wheel Opening Mouldings depending on whether or not there are mud flaps installed.
