  1. Those codes have nothing to do with the window problem. P1602 says you disconnected your battery. Code 45 is a an airbag light code. It says your divers side buckle has a poor connection. Either replace the buckles and remake the grounds (per the TSB) or try and get lucky with some spray contact cleaner.
  2. P0455 Fuel Tank Ventilation System (Major Leak) - Below Limit Possible fault cause - Tank cap missing - Tank cap seal - Ventilation lines detached from EVAP canister - Ventilation line detached from tank - Ventilation line detached from fuel tank vent - Break in ventilation lines
  3. If I look at the parts listing the first year a "Turbo S" cluster was offered was MY05.
  4. Please do a search for +seat +belts -- this has been covered several times.
  5. Bits and pieces from a time long ago... I think on my '76 911S the advance was mechanical but the vacuum on the side just plugged the hole. I may have to see if I can find any old pictures...
  6. We are really testing my memory here... but as I recall it is not used. As I recall when they went with the CD ignition the CD took care of the advance.
  7. I have sent you a PM with a VIN report I had run for you. This should tell you want was ordered (and delivered) on the car.
  8. For legal reasons you are not allowed to copy or print the TSBs. They are for online viewing only.
  9. A couple of Boxster folks (same HVAC unit) have found the noise to be weatherstripping falling down into the air inlet under the pollen filter - then flapping on the fan. I would certainly check there first. Only in a very cases has it been a motor problem.
  10. I would think so if it stuck open. If it were stuck closed the car would not idle at all (no air).
  11. As I recall it rotates like a little door. If it is stuck or sometimes the solenoid goes bad then you need to replace it. Have you checked with Sunset Imports (Porsche Parts at Dealer Cost) for a better price?
  12. Here you go... I hope you are not trying to put this in an older car because the 9x7 series uses a completely different circuit - including a PAS (Porsche Access System) controller.
  13. The parts list says it will only work a 997. I do not know why. It also says: "*997 642 131 05 FMH control part volcano grey/black mat F >>995S7 16151 F >>995S7 41124 see technical information GR. 9 , NR. 7/04 Part has successor (1:1) *997 642 131 06 FMH control part" This says that only for serial number sequences (shown as F >>). It also says it was replaced by 997 642 131 06 FMH
  14. I would start by looking under the dash to see if any wires are dangling down. Did they remove the instrument cluster for the SC install? If so they might have disconnected something there.
  15. 996.613.535.00 light switch -- Retail $112.21 Try the folks at Sunset Imports (Porsche Parts at Dealer Cost) for a much better price.
  16. Then it may be the switch/cable on the Tiptronic. I think you might need a shop with a PST2 or PIWIS to test that.
  17. http://www.renntech.org/forums/index.php?showtopic=1512
  18. Hmm... are you sure they did not unplug the harness to the steering wheel? All of those faults relate to switches in the steering wheel except for the brake light switch fault - that would be the spoiler harness.
  19. I think Cruise Control as a standard option is only for USA/Canada cars. At least that is how it was in the past. Perhaps he has an RoW car - he did not say...
  20. 1. Unclip the switch covers from below and let them dangle from the electric leads. 2. Press together both spring clamps on the display and operator control unit and carefully pull out. 3. Disconnect electrical plug connections from the display and operator control unit.
  21. The older radios have a fuse on the back so I would look for one.
  22. Ok, so the reverse lights don't work... that means that the ParkAssist is never getting the reverse signal - that makes sense. You need to check the switches for the Tiptronic. Does the cluster light come on in reverse ®?
  23. Hmm... you can try 2 digits sequences each side of the number I gave you... or you will need to call a dealer.
