  1. :welcome: Please try our search next time - it works very well... http://www.renntech.org/forums/index.php?s...post&p=9056
  2. Yes, but that is what it states on the sale page "DME 5.2.2" is non-egas cars only. Remember MY97-99 Boxsters use the same DME.
  3. Where are you located? I think you need someone with a PST2...
  4. Yes, rolling diameter.
  5. Porsche does not recommend 11" wide wheels on the rear of a narrow (if they would fit at all). The tire sizes are okay but I would stick with the 10" rear (on a narrow body car). A 285/30 is fine on a 10" wheel. That is what I am running.
  6. That's your oil tank. If you tighten it be sure and support the upper nut (with a wrench) or you might twist it off the tank.
  7. As long as the tires have same N rating are paired on each axle - you should not have a problem. As a rule of thumb you need to be within 4% front to rear. Normally if the system is out of percentage and it is not happy it will throw fault codes. I doubt you far enough off to throw a code. Porsche says "If new tires are to be mounted or the tires of one axle are to be replaced, tires of the same make, the same type and with the same specification code must always be used on each of the two axles. If tires are replaced on one axle only, the different tread depth from that on the other axle can cause a noticeable change in the familiar handling. This is especially the case if new tires are mounted on the rear axle. This effect decreases with increasing tire mileage. Maximum permissible radial runout and lateral runout of the wheels < 0.7 mm. Maximum permissible radial runout and lateral runout of the wheels with tires < 1.25 mm. Values < 1.50 mm - ideally approx. 0.5 mm - are desirable. When replacing a tire on an axle, make sure that the tread depth of the new tire does not differ from that of the other tire by more than 30 %."
  8. Model and year of your car please?
  9. Actually, with a PST2 or PIWIS you can test each individual alarm sensor in the car.
  10. Item 1 in the diagram is the part number Scouser is asking about.
  11. Yes, if you read the alarm fault codes with the Durametric Software, a PST2, or PIWIS tester. It will likely tell you where the alarm faults are.
  12. Did you try to order the old part number (996.107.243.40)?
  13. As of January 2008 the only side vents listed in the parts list are titanium metallic - so I think you would have to paint them. US MSRP $55.79 each
  14. Are you sure there was no ice/snow on the sensor? It is out there in the open.
  15. Randy - I have merged your two topics - please do not double post.
  16. Do you mean the lid for the passenger airbag? (item 44)
  17. You need to look and see what is missing. There are plastic nuts and self-tapping screws that screw into expanders. Tell what is missing and I will look them up.
  18. PCM 2.0 is not PCM2.1. So, I do not know if they could/would upgrade you to PCM2.1 (since 2005 had it).
  19. Have you seen (Cayenne Gen1) TSB 12/05 9153 Satellite Radio Installation Instructions (I No. QV4 QV8) -- dated Jun 13, 2007? As a Contributing Member you can view that here online.
  20. This RennTech does not have a Mercedes site (even though I own an AMG Mercedes). I have thought of starting one but Mercedes technical info is harder to come by than Porsche - hard to believe but true. Renntech Mercedes had a site - I do not know if it is still up. Their site is about selling their tuner cars and kits.
  21. Yes, the new kit works on both 996 and 997 series cars.
  22. Hi Loren So is it exactly same as the 997 GT3 RS Orange? Thanks Yes.
  23. Hi Loren... Is this the link you mentioned? The pictures are quite good...But do you think I can find instructions on how to pop out the AC control unit (what tools do I use...etc) and how to secure it in the new place (where do I place the AC Unit brackets?) It seems that the manual sections (Boxster Technical Manuals Groups 6/7) I mentioned above cover exactly what I am looking for: 68 17 19 - Removing and Installing the Center Console 70 18 37 - Disassembling and Assembling Instrument Pannel Do you know how or if I can get a hold of these? Thanks, Gustavo Um... you have to buy manuals. They were over $2000 when they were in print. The upper console has been covered here many many many times.
  24. The correct number for a MY04 Cayenne S is: 955.504.962.02 Wheel-well liner FYI... 955.504.962.00 was replaced by .02 version 955.504.962.01 was for the Cayenne Turbo and it has been replaced with 955.504.962.03 Do you have all the mounting hardware? Self tapping screws and their expander nut as well as and plastic nuts.
