  1. So the relay was completely gone from your car? Perhaps the previous owner did not like the vacuum cleaner sound at startup? ;)
  2. The ones I've seen/installed came with everything except the bolt.
  3. :welcome: Fronts: 955.521.819.00.SXJ Left headrest with Porsche coat of arms in sand beige/sand beige (MY08) -- Retail $184.48 (as of February 2008) 955.521.820.00.SXJ Right headrest with Porsche coat of arms in sand beige/sand beige (MY08) -- Retail $184.48 (as of February 2008)
  4. Have you contacted the folks at Sunset Imports (Porsche Parts at Dealer Cost)?
  5. Could be just a bad cluster - have they tried a different cluster?
  6. After reseting the DME it will take some driving to get the idle and power curve adopted. I am surprised that you changed the MAF for an idle problem. The MAF does nothing at idle - you can even disconnect it and it won't make any difference until the higher RPMs. If you had/have an erratic idle it is more likely a dirty throttle body and/or an air leak in the intake somewhere (loose hose, loose clamp, AOS failure, or oil filler tube failure, etc., etc.).
  7. Sorry, I think you are going to need to call a dealer or Becker. Last time I checked Becker charged $30.
  8. The serial number is on a label on the radio or on some models you can press a series of keys and have the serial number displayed in the readout.
  9. Looks like the (engine side) accelerator cable and grommet needs replacing. The part number for that cable is 986.423.229.04 and the grommet is 986.423.331.00. If by chance the accelerator cable is undamaged then you just need to replace the grommet. But the cable will need to come off for that.
  10. How did you get your serial number? Through the front panel (as suggested)?
  11. Porsche content here only - please. http://www.dmv.org/ca-california/smog-check.php
  12. The Retail Price Search feature (for our Contributing Members) has been updated to reflect February 2008 pricing for the US (only). We try and update this on a monthly basis as the price lists come available to us. For February 2008 the price lists support: US: 218,495 parts Canada: 209,209 parts (December 2006) Thanks to Contributing Member Porschelibrarian!
  13. Yes, it would be a straight swap. No programming required.
  14. READ this thread - it tells you what to do if the code I give you does not work.
  15. Try 5006 or 5004
  16. It will look like the image below - just not glossy.
  17. It is a 2002 Carrera 4S. Thanks!
  18. Yes, it will fit. It is a two person job to install it (to keep from scratching things).
  19. We need to know the model of your car and model year to get you the correct color codes for the spoiler wires.
  20. :welcome:
  21. We still have not seen PDF files from Porsche of this. You can easily order an Owners Manual from Porsche for under $20. WKD 997 221 08
  22. He is referring to Porsche Technical Service Bulletin (TSB): 1/04 1945 Operating Noises of The Additional Coolant Pump -- dated May 25, 2004 Porsche TSBs are available here to view online by our Contributing Members.
  23. Check the battery - especially if it is 4 years old or older. My money is on the battery or a bad ignition switch.
  24. The Porsche book says 6-7 hours. What city/state do you live in?
  25. Hmm... it does look like something struck it to me. I would take it to the best machine shop in town and ask if they can re-weld and machine the damage. FYI... cylinder head complete -- MSRP $2566.08
