  1. Those are considered "Winter Wheels" for a 996TT. Porsche uses smaller wheels for recommended winter wheels 18 x 10 ET 47 mm - so you can fit chains if needed. 996TT summer rear wheels would be 18 x 11 ET 63/65 mm.
  2. The Retail Price Search feature (for our Contributing Members) has been updated to reflect January 2008 pricing for the US (only). We try and update this on a monthly basis as the price lists come available to us. For January 2008 the price lists support - US: 217,862 parts Canada: 209,209 parts (December 2006) Thanks to Contributing Member Porschelibrarian!
  3. No. Any immobilizer change requires reprogramming using a PST2 or PIWIS and your car's unique IPAS code (available only from Porsche).
  4. Read my latest blog entry (Product claims and dynos -- and reality) ...
  5. 996.641.142.00 temperature sensor -- US MSRP $14.07
  6. You can try drying out your immobilizer and praying. If it has shorted out hen you have to get a new one AND have it programmed to your keys and DME.
  7. :welcome: Rector - why? Peter Smith -- shop foreman, 20 plus years as a Porsche tech, PCA Technical Committee, races a 944 in his spare time. A good guy all around (but don't tell him I said so).
  8. 955.107.561.00 Oil filter and o-ring -- US MSRP $14.85 also get a new o-ring for the oil filter bolt (if you open that drain bolt). N 903 054 02 o-ring US MSRP $3.65
  9. You do have to re-login when you go to the Reviews section as it is a different application that treats cookies differently. The main site should work fine with IE7. It does for me.
  10. ... or a cracked tank.
  11. Please have some patience - please allow 24 hours for responses to your questions. Check to see if anything fell into the fan area (under the pollen filter) and if it smells musty then the AC condensor drain may be plugged. If it is the drain then clear the drain and then run the heater as hot as it will go. It might also help to some disinfectant into the area of the heater core.
  12. Cayenne S and Cayenne Turbo are the same procedure. http://www.renntech.org/forums/index.php?s...ost&p=78411
  13. Please try a search here as window problems and causes have been covered many times here.
  14. You need to have your car checked with a PST2 or PIWIS - they can individually test the circuit and likely tell you where the problem is.
  15. There are different part numbers for the Cayenne Wheel Opening Mouldings depending on whether or not there are mud flaps installed.
  16. 999.500.128.00 Nut (new style)
  17. Sorry, I don't see any instructions. Aren't they just installed with double stick tape?
  18. My information comes from the Porsche OBD II manual (5.2.2) which covers your model year car. Yes, reset the DME. The adaption values are the TRA, TRA2 and FRA, FRA2. Most generic OBD II readers can not read those values.
  19. 000.044.500.08 is the kit. We always recommend the kit over individual parts. Use the -20 rear stabilizer (not the -15)
  20. Sounds like a bad sensor or control unit. Porsche had a problem back in 2003 with these - but that was fixed. Best have your dealer/OPC out their PIWIS tester on it.
  21. Model and year of your Cayenne please?
  22. Try 1366 or 1364
  23. Yes, just be sure to mark the cables first.
