  1. http://www.renntech.org/forums/index.php?showtopic=5 Could be just a bad sensor - there have been a few of those.
  2. Try 1298 or 1296
  3. Just center at the very edge of the lower spoiler.
  4. Not a stupid question - yes, the 997 engine oil change procedure is the same as the 996.
  5. Try 2937 or 2935
  6. Try 0462 or 0460 Thanks for the quick reply. I'm puzzled, however, at how to enter the code. Currently the screen is showing "Wait". What's my next step? Please READ through these posts - it's all been covered here many many many times.
  7. Have you tried cleaning the sunroof slide rails? Sometimes sticky rails can cause erratic actions.
  8. I am pretty sure Tool Pants has covered this here before. I have watched him drill the old one out so I think that is the only option.
  9. Try 0462 or 0460
  10. Just drop me a message or one of the moderators and we will take care of it. I have already done so in this case.
  11. It's been covered here many times - please try using the search...
  12. Try 6833 or 6831
  13. On the 987 the Service Manual says: "Oil change quantity with oil filter 7.75 litres"
  14. 1. No need to disconnect the battery. You should not cause any faults unless you forget to plug the MAF or throttle electronics back in. 2. These are all very low torque screws - unless you have an inch pounds torque wrench I would just get them tight with a short wrench (not too much leverage that way). 3. Might not hurt since you will be in there anyway.
  15. P0133 Signal Period for Oxygen Sensor Ageing, Bank 1 – Above/Below Limit P0153 Signal Period for Oxygen Sensor Ageing, Bank 2 – Above/Below Limit Potential causes: – Oxygen sensor ahead of TWC – Wiring (oxygen sensors exchanged)
  16. That part number is for a 997 widebody C4/C4S.
  17. :welcome: Yes, it will fit with a little work. Please do a search here as this has been covered a few times.
  18. I think you will need to change the bumper to fit the other front spoiler lip. Probably best to confirm exactly which front bumper you have - because dealers are not supposed to add the rear spoiler without the adding the front bumper/spoiler. The correct part number for the Aerokit Cup II front bumper is 996.505.986.02.G2X.
  19. In Fremont - talk to Alex at Sharkwerks - tell him I sent you. Oh... I think he only does GIAC - but ask him. (510) 651-0400
  20. Perhaps you can find someone local with a PST2 or PIWIS that will turn it on for you. It only takes 5 minutes.
  21. Check for a bad connection in the steering wheel.
  22. No the Durametric does not do that (yet). I am on North side of Roseville - I can reprogram your door locks -- for free. PM if you want to get together.
  23. :welcome: We suspect that 226 is 18" tires. My car has that option too and it is the only thing missing from any Porsche lists. As of MY02 the fuel filter is in the fuel tank and never needs replacing (under normal use).
  24. Sounds like a bad ground connection or bad socket.
  25. This would indicate an O2 sensor is not reading/operating correctly - or you have an exhaust leak.
