  1. There are no plastic rivets on the front bumper - there are plastic rivets on the wheel liners. 999.507.497.40 plastic rivet -- US MSRP $0.31 each
  2. Without the fault code(s) it is anybodies guess. You need to get eht fault codes read and report back here.
  3. Fault code 9115 Air-conditioning control module Possible cause of fault: - Open circuit of CAN-high Comfort - Open circuit of CAN-low Comfort - Air-conditioning control module faulty You are likely going to need someone with a PST2 or PIWIS for further diagnosis.
  4. In most cases it is fine to just top up the oil level. The RMS does not leak any oil when it is changed. The IMS does leak oil (since it is lower on the crankcase) when changed. If they change the IMS then they can catch the oil and reuse it.
  5. Have you tried a search here? I have posted the BOSE diagram several times.
  6. Try 5565 or 5563
  7. You need to do the buckles and the ground wires under the drivers seat. Theoretically the later buckles should be the gold plated ones - let us know how they work out.
  8. Depends... if your car has telephone prep (and most US cars did). Then it should be on the E-Handy connector under the passenger seat. Should be a Yellow wire with Black stripe (A4 of the handy connector).
  9. P1128 Oxygen Sensing Adaptation, Idle Range, Bank 1 – Below Limit P1130 Oxygen Sensing Adaptation, Idle Range, Bank 2 – Below Limit Potential causes: – Incorrect signal from MAF sensor – Fuel pressure too high – Fuel injector leaking – EVAP canister purge valve open P1115 Oxygen Sensor Heating Ahead of TWC, Bank 1 – Above Limit P1115 Oxygen Sensor Heating Ahead of TWC, Bank 1 – Below Limit P1115 Oxygen Sensor Heating Ahead of TWC, Bank 1 – Open Circuit P1115 Oxygen Sensor Heating Ahead of TWC, Bank 1 – Signal Implausible You need more investigation here. Potential causes (depending on further investigation): – Heating resistance too low – Short to B+ – Corrosion in connector – Break in wiring except for a few litz wires – Heating resistance too great – Oxygen sensor
  10. Try 5016 or 5014
  11. Try our Search feature next time - it works very well. How to remove fuel filler door
  12. The drain plug will depend on your exact transmission model. Best check with JeffClark at sunsetimports.com
  13. Loren, As always your valuable insight is much appreciated. Last time I changed the tranny oil, I remember the fill and drain plugs were up for replacement next time. Do you have part numbers for these two items? Regards JP Why would the plugs need replacing? Or are you planning on damaging them? Porsche even says to reuse the sealing washer on the fill plug.
  14. Try 9112 or 9110
  15. Please use the one Lost Radio Code topic. This thread is now closed.
  16. The Service Reminder can be reset with the Durametric Software (about $247) or by any shop (or owner) with a PST2 or PIWIS. The original method only seemed to work on a few of the early cars.
  17. How old is your battery? If it is 4 years or older - then it's time for a new one. Have it tested (specific gravity) if you are unsure. Any other strange electrical problems? - if there are then you could have a bad ignition switch. Might not hurt to check the cables on the starter and the starter solenoid - as well as the engine to chassis grounds.
  18. Try 2340 or 2338
  19. Your car does not get the new MAF - you should continue to use 996.606.124.00 for all egas Carrera's MY99-01 (except for MY99 C2 non-egas)
  20. That link is in the Contributing Members Only forum...
  21. N-Spec Tires, Everything you wanted to know from Porsche Read the TSB on Summer Tires - it explains the date codes on tires.
  22. Sorry, I think you need to read your owners manual. "Connect jumper cables in the following sequence: 1. Check electrolyte level of each cell. If necessary, fill with distilled water to just above plates. 2. On a vehicle with a discharged battery: turn off all consumers and accessories, move the gear shift lever into the neutral position and set the parking brake. 3. Attach the positive cable first to the positive terminal 1 of the booster battery A, then to the positive terminal 2 of the discharged battery B. 4. Connect the negative cable first to the negative terminal 3 of the discharged battery B, then to a suitable earthing point 4 on the body of the vehicle with the booster battery. This earthing point must lie as far as possible from the battery. 5. Run the engine of the booster car at a higher speed. 6. Start the engine. An attempted start using jumper cables should not last more than 15 seconds. Then allow a waiting period of at least one minute. 7. With the engine running, remove both jumper cables in the reverse order."
  23. Try 7167 or 7165
