  1. :welcome: Have you asked them about a Porsche Exchange transmission (Porsche rebuilt)? I show an MSRP on those of only $8049.65 (with exchange).
  2. :welcome: Look at the first category Country Codes (all models)
  3. Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  4. From what I can see it looks to be highly likely an RMS or IMS leak. Both should be checked - and if there is oil on the clutch disc you will need a new one of those too.
  5. Removing 1. Removing air cleaner assembly 2. Removing air cleaner assembly 3. Loosening belt pulley of the hydraulic pump 4. Relieving and removing drive belt 5. Loosening three-phase generator 6. Loosening air-conditioning compressor 7. Loosening air-conditioning compressor 8. Removing throttle body 9. Removing supply tank of the power steering system 10. Removing supply tank of the power steering system 11. Detaching steering return line 12. Detaching steering return line from the supply tank with tool 13. Detaching hydraulic pump and steering supply line Removal Procedure: 1. Removing air cleaner assembly. Undo the hose clamp on the throttle body. Remove connector from hot film mass air flow meter. Unclip electrical lead on throttle body. 2. Removing air cleaner assembly. Unclip oil filler neck. Undo hexagon-head bolt M6 x 20 and remove entire air cleaner assembly. 3. Loosening belt pulley. Undo three hexagon-head bolts (M8 x 12) by approx. one half turn. Note: The belt pulley can also be loosened with a restraining strap after removal of the drive belt. 4. Removing drive belt. Mark belt travel direction with a colored pen. Slacken belt by turning the tensioning pulley (wrench size 24 mm) clockwise, hold still and simultaneously take the belt off the drive pulleys. 5. Loosening three-phase generator. Undo right-hand fastening screw (in direction of travel) and unscrew. Undo left-hand fastening screw (with deflection roller) by three turns. A gentle tap on the fastening screw loosens the threaded bushing in the generator arm (use aluminum mandrel). 6. Loosening air-conditioning compressor. Undo front compressor fastening screws (2 ea.) and disconnect electrical plug connection. Lift generator up and out of the slotted generator bracket. Unscrew fastening screw and remove with deflection roller. Note: Do not disconnect electrical connections or plug connection. 7. Loosening air-conditioning compressor. Undo compressor fastening screw between the intake pipes of cylinders 4 and 5. 8. Removing throttle body. Disengage accelerator cable and remove throttle body. Pull off vacuum check valve. 9. Removing supply tank of the power steering system. Suck fluid out of the upper supply tank until the level is below the joint. Turn bayonet lock ring counter-clockwise. 10. Removing supply tank. Detach bracket from supply tank and B+ disconnection point and set aside. Pull supply tank up and off. Suck off fluid level of the lower supply tank and then immediately close the opening with a suitable plug. 11. Detaching steering return line. In order to detach the line from the supply tank, push the red unlocking ring forward (arrows) and simultaneously pull out the line. Use two plastic spatulas to press the unlocking ring. 12. Detaching steering return line from the supply tank with (special) tool. The line can also be detached using a commercially available tool. The removal tool from Snap-On, for example, is recommendable. Insert tool between line and the red unlocking ring and unlock. Pull line to the rear and simultaneously press the tool against the red ring. Carefully protect the line against dirt and scratches with a cap. 13. Detaching hydraulic pump and steering supply line. Undo steering supply line (wrench size 17); simultaneously counter at the body (wrench size 27). Undo three hexagon-head bolts (M8 x 12) and remove hydraulic pump to the rear. Note: If coolant hoses come into contact with Pentosin, clean them thoroughly without delay. 14. Removing bracket with tensioning element. Undo flange for oil filler neck at the left rear bracket fastening screw. Immediately seal bore on the crankcase. Undo four hexagon-head bolts and remove bracket with tensioning element. Installing 1. Installing hydraulic pump. Fasten bracket with tensioning element on the crankcase. Tightening torque 23 Nm (17 ftlb.). Insert hydraulic pump from the rear and fasten. Tightening torque 23 Nm (17 ftlb.). 2. Fitting steering return line. Insert line into the plug-in coupling in a straight line. Then pull slightly to ensure that the connection is properly locked. 3. Fitting supply tank for power steering system. Turn bayonet lock to its initial position. 4. Fitting supply tank for power steering system. Remove plug. Position tank (observe markings). Lock bayonet lock. 5. Fitting drive belt. Fit belt pulley of the hydraulic pump and screw in hexagon-head bolts. Fit drive belt. (See the DIY on changing the polyrib belt). 6. Fastening belt pulley for hydraulic pump. Tighten three hexagon-head bolts. Tightening torque 23 Nm(17 ftlb.). Note: The belt pulley can also be held and tightened with a restraining strap before the drive belt is fitted. Fasten air-conditioning compressor. Tightening torque 28 Nm(21 ftlb.). Fasten generator. Fit throttle body and air cleaner assembly.
  6. We have added and/or updated TSBs in the following categories (17 TSBs total): 987 - 1 Cayman - 1 996 GT3 - 1 997 - 1 997 TT - 1 997 GT2 - 1 997 GT3 - 2 Cayenne (gen 1) - 4 Cayenne (gen 2) - 5
  7. Try 4698 or 4696
  8. Loran, Okay, I've looked all afternoon and besides what Joost has posted, I haven't found much on making the OBC work in my car. As Joost has said, "the toggle switch is simple" but I can't find anything about a DIY on putting the stalk and related connections on? I know I'm asking a question that has be asked (maybe many times) before, but I can't find the answer in the search area(there is everything from exhaust to headlights when I put "install OBC stalk" or "OBC switch", for example). I've looked in your DIY area and can't find anything either, so any help would be great. Thanks, again, for your time, C'ya, Did you look at the two links he posted?
  9. You will need to cut the original connectors and you will only need two of the four wires - so tape the other two well.
  10. Look at the thread (further down on that same page - I posted a pic with both the Cab and Coupe drains. The coupe are indeed behind the rear tires and behind the front tires.
  11. Most of the time a bad switch will give you many flaky lights.
  12. To bleed the ABS you do need a PST2 or PIWIS. Most folks do not think the at the amount of fluid in the ABS controller is significant enough to worry about. I agree, I own a PST2 and I usually do not bleed the ABS. Especially if it is just a normal flush and bleed. Unless you have replaced whole parts or lines there is not reason for any air in the ABS system. Most dealers that I have watched don't bleed the ABS either for a normal brake flush service.
  13. Did you check the connector on the headlight for bent pins? Likewise the connector that stays in the car body when you remove the headlight. Check of a broken connector or pins pushed out of the connector.
  14. Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  15. On 996 Carrera's... A/C runs down the right side (passenger side on LHD). Brake lines run down the left side. As does the clutch line. Fuel and engine cooling run down the center tunnel.
  16. Try 5498 or 5496
  17. 996.555.557.09.A03 Light cover (in black) -- US MSRP $77.99 You should try Sunset Imports (Porsche Parts at Dealer Cost) for a much better price.
  18. Try 3680 or 3678
  19. OBC (On Board Computer) is the correct term. If your outside temp is showing on the tach display then your OBC is "on". To see the other displays you need the 4th steering wheel stalk that switches between the various functions - it goes under the turn signal indicator. A few folks have added a momentary switch on the dash that does the same switches between the various functions. Both mods have been covered here. But check first and see if you have the 4th stalk.
  20. Or there is the Porsche solution... As I recall these are not too expensive.
  21. 180 F is normal driving temperature (not below) - it will go up a little if you are stopped in traffic.
  22. Thanks Loren. Sorry for the late reply but I was waiting for an email notification but didn't get one. Is the forum set up for this? In the option button on the right side you select to "subscribe" to a topics or a complete forum. If you later want to turn that off - just go to your My Controls area and change it under "Subscriptions".
  23. Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  24. My point is a few drops of oil on the ground does not make it an RMS leak - so isn't the cost irrelevant at this point? There is no way to tell where the oil leak is coming from without looking closer. There are other areas that can leak that are not RMS or IMS. If you don't feel comfortable looking closer or have the tools then find a good Porsche shop that can have a look for you. Where are you located?
