  1. Try 7373 or 7371
  2. Did you get the tool for the shock/coil adjustment? If not got back to the shop and ask for it - it came with the coilovers.
  3. Psst... I am not a psychic ;) I need your serial number... Lost Radio Code - FAQ, PLEASE READ THIS FIRST oops serial 15062050 model BE 4462 Try 0020 or 0018
  4. And my image from the parts list also show option XPA (IXPA). So, either the parts list is wrong or they gave you the wrong part.
  5. Psst... I am not a psychic ;) I need your serial number... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  6. Try 4788 or 4786
  7. I tried the codes you gave me and they didn't work. Do you have more codes? Thanks again, John did u try with these above details Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  8. Hi....im from germany...the same problem....lost my radio code for my BOXTER Radio CR 210 Mod R 3297 Ser Nr. V5008018 Please Help..... Try 1143 or 1141
  9. Try 3028 or 3026
  10. Try 5129 or 5127
  11. I just bought a 1999 Boxster and I need the radio code. The dealer put a new battery in and the code card is not in the car. I would really like to listen to some music. Here is the info, CDR-220 Serial # X5021245 Model# BE 4462 48/98 Thanks, John Try 2522 or 2520
  12. All the radios in Porsches since MY03 have been MOST. You likely need to turn options on/off in using a PIWIS so that the new car knows what is plugged in.
  13. Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  14. That signal is no longer on the OBD II plug. Almost everything on the 9x7 series cars is on the CAN bus.
  15. You need a new ignition switch - it is a common problem on the older cars. Replacing the Ignition Switch DIY
  16. Did you look in the links section? Becker of North America
  17. :welcome: P0116 Engine Temperature – Signal Implausible Possible fault cause: - Thermostat (permanently open) - Open coolant shutoff valve (only Tiptronic vehicles) - Wiring - Temperature sensor faulty - DME control module faulty I hope they did that work under warranty - because it sure looks like they shotgunned it instead of finding the root cause. I would not worry if it does not pass the zero in 180. Still you might want to check and clean the front intakes (in front of the radiators).
  18. They still call it "Sports Steering Wheel". Here it is in the parts list.
  19. 997.347.980.00.xxx Where is xxx is the color code (i.e. A34 would be black leather)
  20. Try our Search - it does work :) http://www.renntech.org/forums/index.php?s...ost&p=80216
  21. Perhaps you want the 997 GT3 RS steering wheel?
  22. :welcome: Replacing the Ignition Switch
