  1. I still think... Could be just a bad sensor.
  2. :welcome: Please try our search - this has been covered many times.
  3. Either read the width and offset off the wheels or get the part numbers. Fronts should be ok - rears may need spacers.
  4. :welcome: What diagnostic tool is he using? Have you tried another key?
  5. Model and year of your car please...
  6. http://www.renntech.org/forums/index.php?s...dpost&p=742
  7. Too bad for you... the Porsche (NA) Tech training classes used to be in Las Vegas. I think they are only in Atlanta now - but then you would need to get hired by a dealership first. ;) Ask your questions here and some folks that are more familiar with the tools will try to answer them.
  8. P0455 Evaporative Emission System Leak Detected (large leak) Possible cause of fault - Tank cap not tightened correctly, faulty or missing - Mechanical fault in EVAP canister purge valve (does not close fully) - Leakage diagnosis pump leaking internally (membrane) or externally - Mechanical fault in EVAP canister shutoff valve (does not close fully when power is supplied) - EVAP canister shutoff valve connections leaking - Tank system (including pipes) leaking Check your gas cap and seal. There have been some changes to the gas cap so you might want to make sure you have the latest revision.
  9. Sorry, not that I have seen.
  10. Just do not connect the gray/pink wire.
  11. Try 0439 or 0437
  12. Maybe start by checking the fluid level.
  13. Try 9224 or 9222
  14. :welcome: Please do a search here this has been covered many many times.
  15. I am not recommending anything beyond 18" wheels - I am saying 18" wheels are ok on MY99-MY05 cars.
  16. P0734 Gear monitoring, 4th gear - signal implausible Potential causes: - ATF level not OK. - Mechanical/hydraulic fault in transmission. - 34 (e.g. solenoid valve does not operate despite correct electrical triggering) - Solenoid valves - Valve chamber - Transmission
  17. Harbor Freight -- $7.99 100 Piece Security Bit Set
  18. For a MY03 996 the correct plugs are FGR 5KQE0 - part number 999.170.223.90 Looks like they gave you Cayenne plugs.
  19. Shouldn't be anything special - just top up the power steering pump reservoir until all the air bleeds out.
  20. Yes, I was suggesting a trade for a Turbo 996.
  21. You will likely get a small bump (less than 10 HP) from headers and sport exhaust. The plain answer is Boxster's and Carrera's are pretty much maxed out - if you want a lot more more trade for a Turbo. The Turbo's actually respond very well to exhaust and chipping.
  22. My advice is - save your money. None will give you any more HP, perhaps a little more induction noise, and most often a damaged MAF. (IMHO)
  23. :welcome: I doubt that could have been done with a PST2 or PIWIS - more likely a 3rd party re-programming tool. I have seen DME's trashed (made unprogramable) by a bad 3rd party flash. You need to see the MAF readings at idle and 2500 RPM to see if it is a bad MAF or some other problem. It is not an O2 sensor - those faults say your mixture is so rich the DME can not make it lean enough. Where are you located?
