  1. US MSRP on the fuel pump is $308.86 - I am sure Sunset Imports can do much better than that. Labor sounds pretty high to me. I would get a quote from an independent Porsche shop. Make sure they have a PST2 or PIWIS as they will need to calibrate the fuel gauge after replacement.
  2. 996.551.980.298.VRK Lining in black leather -- US MSRP $706.20 I do not see any options for deviated stitching - if that were available then it would likely be a special order (and about 2 months to delivery).
  3. Probably not related to the coils problem. The coils problem can cause stumbling and/or hesitation and/or misfires. TSBs (all of them) are available here to view for our Contributing Members. Contributing Members can view TSBs online, use the Retail Price Search feature, and access the Contributors Only Forum. They can send attachments with PMs, image storage limits are raised for all Contributing Members, RennTech.org email addresses are available and a personal Blog. Contributions help defer the cost of running this site and providing this information to you. No one has to contribute but many members do. Without contributions this site would either have to go subscription or cease to exist.
  4. Try 0837 or 0835
  5. Hmm... Check your brake lights. If they do not come on - then that is the cause. If the brake lights work then you might try a new MAF.
  6. 4000 RPM in 5th gear (Tiptronic) is over 110 MPH. Very few places you can do that sustained.
  7. Looks normal too me. If you do not get your engine hot or do short drives what you see is normal. As long as there is no oil in your coolant you should be fine.
  8. Try 8846 or 8844 Neither one worked, I guess I'm at the mercy of the dealer? Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  9. Try 8846 or 8844
  10. Loren
    Motor oil
    Yes, and it is the ONLY Porsche approved 5W50....last I read in Panomara. Yes, Mobil 1 5W-50 is the only 5W-50 on the 11 page March 2008 Approved Oils List.
  11. Try 4193 or 4191
  12. Yes, the service manual actually says: "Thinly grease thread, shank and under head (between screw head bearing surface and spherical cap ring) of the wheel bolts with Optimoly TA (aluminium paste). Do not grease bearing surface of the spherical cap facing the wheel. If heavily contaminated, clean bolts first with a lint-free cloth." Optimoly TA -- US MSRP $27.11 for 100 grams!
  13. Loren
    Motor oil
    Yes, 5W-50 is approved for all Porsches (except Cayenne V6) from model year 1984 through present.
  14. Try 8507 or 8505
  15. > Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  16. i don't believe so but i am the 3rd owner, how would i tell, i guess by removing the center console? No, you just need to lift the shift boot. (4 snap clips)
  17. Get a PPI and/or CPO warranty. I do not think the 3.6 is any more reliable than 3.4 - they are pretty much the same.
  18. Are both lights on and you get a display message? or just both lights?
  19. I think what have is Permatex Anti-Seize
  20. Item 8 - Lower control arm -- US MSRP $335.41 (each) Check with Sunset Imports (Porsche Parts at Dealer Cost) for better pricing.
  21. 8.5 x 18 were not stock on 996TT and only optional after MY03-- only on GT2. The rears are likely ET 45 so I think that will be a real problem. I think you might get 10's under the rear fenders (if rolled) without rubbing (depending on tire size) but I don't think 11's will work. Perhaps some Boxster owners can chime here...
  22. Porsche recommends a small amount of anti-seize on the bolt threads only. A small amount should not have a bad effect on torque settings - plus or minus 10 ft/lbs. is okay.
  23. Yes, if you disconnect the battery is does have to re-learn. Just drive it as you normally would - it may take 5 miles or so to re-learn. Loren, Thanks for the reply. I cleaned the idle air valve and it helped tremendously. Car went for 2 days without a problem, rock solid, until this evening and started again. I noticed when I was cleaning everything, the plastic hose that connects the oil seperator to the throttle body had oil in it. It was wet enough to cover my finger, so I cleaned it as best I could. Is there a procedure to clean the seperator, or is it replace only ? Also, is it possible that the two problems are related, as in, a vacum problem not venting the crankcase ? Thanks for your advice ! If there is oil in the throttle body then you likely have a bad AOS. This would also cause a vacuum leak (and corresponding fault code).
  24. I still think... Could be just a bad sensor.
