  1. I can make back to back to back dyno runs on my car with nothing changed and get more HP every time. See my blog entry here for my of my thoughts on product claims and dynos...
  2. Goo Gone will also remove wax - so after I use it I use a paint cleaner and then wax again.
  3. Hi, I am having the exact same problem with my Boxster and am hoping you have gotten to the bottom of it, so I can as well:) Any news and/or luck? Thanks in advance, Rob Please do a search here - this has been covered many many many times here.
  4. This is the Porsche Club site for the San Francisco region.
  5. Try 3028 or 3026 hi loren neither of these worked, any ideas?? im really stuck Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  6. :welcome: http://www.renntech.org/forums/index.php?s...p;hl=fan++speed http://www.renntech.org/forums/index.php?s...p;hl=fan++speed http://www.renntech.org/forums/index.php?s...p;hl=fan++speed http://www.renntech.org/forums/index.php?s...p;hl=fan++speed and many more...
  7. Try 3028 or 3026
  8. http://autorepair.about.com/library/images/bl255a-lib.htm Try it with a regular Phillips first - but don't strip it out if is very tight. I can only remember having to use an impact driver on one car and it had a lot od rust and a lot of years.
  9. Try 8658 or 8656
  10. :welcome: There was no C4S in MY1999 (C4S started in MY02) - so perhaps your car is a C4? What are your fault code(s)?
  11. Try 1143 or 1141
  12. A bad ignition switch could cause a battery drain - if the wrong parts are shorted and always on.
  13. Psst... I am not a psychic ;) I need your serial number... Lost Radio Code - FAQ, PLEASE READ THIS FIRST oops serial 15062050 model BE 4462 Try 0020 or 0018 Neither of these worked, any more options? You didn't read this did you... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  14. I suggest you write down the fault codes before you reset them - in case the problem comes back. Most tools have a selection of "clear faults" or "reset faults".
  15. Thanks for the quick reply. I am not familiar with the CAN Bus? Is it something I can access and tap into? Where is it located? Some of the more sophisticated telemetry systems use the CAN bus - you can tap in at the cluster or the DME.
  16. What do you mean by exhaust? mufflers or cats? Changing the mufflers will not cause any faults or error messages. Changing the cats might.
  17. Try 7373 or 7371
  18. Did you get the tool for the shock/coil adjustment? If not got back to the shop and ask for it - it came with the coilovers.
  19. Psst... I am not a psychic ;) I need your serial number... Lost Radio Code - FAQ, PLEASE READ THIS FIRST oops serial 15062050 model BE 4462 Try 0020 or 0018
  20. And my image from the parts list also show option XPA (IXPA). So, either the parts list is wrong or they gave you the wrong part.
  21. Psst... I am not a psychic ;) I need your serial number... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  22. Try 4788 or 4786
  23. I tried the codes you gave me and they didn't work. Do you have more codes? Thanks again, John did u try with these above details Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  24. Hi....im from germany...the same problem....lost my radio code for my BOXTER Radio CR 210 Mod R 3297 Ser Nr. V5008018 Please Help..... Try 1143 or 1141
  25. Try 3028 or 3026
