  1. Did the old cap part number end in "00"?
  2. Try 5498 or 5496
  3. Try 0706 or 0704
  4. Try 2565 or 2563
  5. Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  6. Contributing Members can view TSBs here online. How to become a Contributing Member
  7. Same and common issue.. why doesn't owners write this code down in the manual or something. Hope you can help Becker 4462 radio SN Y5046187.. I tried 6401, 6403, 6404 I am back to wait.. Wayne Try 0860 or 0858
  8. Everyone here is entitled to there own opinion. Please respect your fellow members opinions. There is need to flame other individuals - please re-read the board Guidelines/Rules (that you agreed to when you registered here).
  9. I have the Bird armrest and really like it. I was in Connecticut last Christmas, gave Bird Automotive a call and met Sam Bird. Because of the price, I wanted to see it before I bought it. It is made very well, fits and looks like it was an original installation. It adds a drink holder which works well. Only comment is the drink holder is a little short so don't plan on putting any really tall cups in it. My interior is black so it was an easy match but even the texture of the leather is the same as the interior. He also makes a bicycle rack for the back of the vehicle that attaches underneath. Dave T 99 Carerra Doesn't the Bird arm rest still use some of the components of the base armrest, if so he still needs to use the hinge rivet kit. The armrest has a new hinge. The lid is the same but you install new components for the hinge. I'm not sure what you mean by the "hinge rivet kit". See the TSB for fixing the center console hinge...
  10. Try 7729 0r 7727
  11. I think you are looking at a lot of work (including wiring for a very old - not very good) NAV system. There are much better after market NAV systems available today.
  12. HI Lore, I would like to request for a radio code for my 1999 996 coupe. Thanks in advance. CR220 type BE4466 serial number W5008009 Try 1071 or 1069 Hi Loren, The numbers 1071 or 1069 did not work. Any other ideas? Also, howcome the model says cr2200 instead of cr220? Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  13. Are you sure you are not just under the trim instead of the console it's self? Trim piece is item 29 ( and held in place with clips)
  14. HI Lore, I would like to request for a radio code for my 1999 996 coupe. Thanks in advance. CR220 type BE4466 serial number W5008009 Try 1071 or 1069
  15. As long as the antifreeze is organic antifreeze made for alloy engines.
  16. If you were in stop and go traffic then it looks about right. It should come down to 180 - 190 with speed. You might want to make sure your radiators are clear of debris (leaves, paper, dead birds, etc.)
  17. No SHOUTING here please (typing in ALL CAPS). I don't think anyone here has flamed you - just asked you why.
  18. Motorcycle mode: 14.4 Volts at 0.8 A (Primarily for batteries of the less than 14 Ah) Car mode: 14.4 Volts at 3.3 A (for all batteries greater than 14 Ah)
  19. What is VSS speed signal? If so, it is the violet green wire on the OBD II plug under the dash (on the left). The speedometer signal is any Gray/Pink wire from the cluster or NAV.
  20. What are you trying to do? Hook up a shift light? Both the speed wire and shift monitor wire have been discussed here before.
  21. Could have been just a vendor change - but there was no TSB or no update to the previous TSB which says to use .03.
  22. Try 9095 or 9093
  23. There is a TSB that describes all of the "approved" tires, wheels and spacers.
