  1. Use MAF sensor cleaner only. CRC is a good brand.
  2. It will likely break and you will need a new solenoid anyway.
  3. Did you follow the procedure in the Lost Radio Code FAQ to get the correct serial number?
  4. Calibration is easy but requires Durametric, PIWIS or PST2. Certainly worth a try before throwing money at it.
  5. Lost Radio Code FAQ
  6. A double beep means you have an alarm fault. You will need Durametric or a Porsche PIWIS to diagnose the exact alarm fault.
  7. Did you use the Lost Radio Code FAQ procedure to get your radio's correct serial number?
  8. I would tend to agree. While it is always best to have zero leaks a drop or two per week is nothing I would be concerned about. My 996 Rear Main Seal (RMS) leaked about a drop a week for 5 or 6 years. I never repaired it nor did it leak enough to require adding any oil between oil changes. Of course if leaks more it would need to be dealt with.
  9. I buy all my single use or very low use tools from Harbor Freight.
  10. In both cases you will likely need Durametric or PIWIS to diagnose and pinpoint the problem(s). The modern electronics in these cars today run all accessory features through electronic controllers that can be easily tested for component failures.
  11. Sorry, I can not help with your Becker Mexico Pro. We only cover the Porsche radios as stated in the Lost Radio Code FAQ
