  1. You will need the Durametric software, a PST2 or PIWIS to reset the airbag code. Where are you located? - perhaps someone near you has one of these.
  2. Check your engine oil level. If it is at the full mark you might want to drop down a couple of bars.
  3. Try 0479 or 0477
  4. Try 0744 or 0742
  5. You have an alarm fault that is preventing it from arming. You need to investigate with the Durametric software, a PST2 or PIWIS tester.
  6. Sounds like the after market pipes are undersize...
  7. Look in your maintenance book for the wheel lock key code. If you do not have that then ask your dealer to look it up. If that fails, your dealer should have a set of wheel lock keys - and they try them untill they find the right one and then order that one.
  8. LOL - No dealer in their right mind would refuse to fix a safety issue.
  9. The service manual says: "Side-airbag sensor (sensor for airbag) Fault codes 85, 87" "1. There is an open circuit in the wire to the sensor. 2. There is a short to ground / voltage between pin 3 (sensor for airbag) and control module pin 20 or pin 21 3. The sensor or control module is faulty. Check wire to the sensor for open circuit / leakage resistance. If no fault is detected in the wire, replace sensor"
  10. I have done it with a PST2 and it literally takes about 2 minutes (providing nothing is still broken). I would try to fins a show with a PST2 and pay them for the minimum time to do the calibration.
  11. The 996 service manual has had 99 supplements - so some of those online freebies are worthless. (I know I bought all 99 supplements) ;)
  12. Can you ask the tech that looked on the car? It is just random guessing without fault codes.
  13. Sorry to hear your misfortune. What were/are the fault code(s)?
  14. 999.500.092.00 Nut -- US MSRP $2.94
  15. Someone has overtightened it. You will likely need to reach under from the battery side and hold the rubber enclosed nut to keep it from turning. If it is badly damaged (nut pulled through) then you will need to replace the rubber enclosed nut. They were only a couple of dollars last time I checked.
  16. Either will work fine. 996.559.211.00 has replaced 993.559.211.00. In many (but not all cases) the last two numbers are revision numbers.
  17. If you have PSE then you would have that relay somewhere in the relay panel. (unless of course someone removed it). Older relays might end in .01 or .02 instead of .03.
  18. Model and year of your car please. Also, Litronic/Xenon or Halogen lights.
  19. Removal 1. Disconnect the battery and cover terminal or battery. 2. Remove driver's airbag unit. For this purpose, loosen the two fastening screws with a screwdriver for internal Torx T 30. Disconnect plug connection at airbag unit and at steering wheel (for horn). Note: Replace fastening screws whenever they have been loosened. The airbag unit must always be set down so that the cushioned side faces upwards. If removed for an extended period, the airbag unit must be kept in a locked place. Observe the safety regulations. 3. Loosen hexagon nut and remove together with spring washer. 4. Turn wheels to straight-ahead position. Then mark the position of the steering wheel with respect to the steering shaft (for refitting). Remove steering wheel (in straight-ahead position). Note: To prevent unintended rotation of the contact unit (KE) when the steering wheel has been removed, the contact unit locks itself when the steering wheel is pulled back. Likewise,the contact unit unlocks automatically when the steering wheel is refitted. Installation 1. Refit the steering wheel with the wheels in the straight-ahead position or in accordance with the marking so that the upper spokes of the steering wheel are horizontal. Caution: Do not trap the cable of the contact unit. 2. Fit hexagon nut with spring washer and tighten to 46 Nm (34 ftlb). 3. Install driver's airbag unit. Use new fastening screws. Tightening torque: Tightening torque 10 Nm (7.5 ftlb.) 4. Check horn for operation.
  20. That says all of your O2 heating current is too low. Perhaps they are the wrong sensors - wired incorrectly.
  21. Replacement is covered in the service manual - which is what dmcole used. I have several pdfs of the service manual, but the closest thing I find is Group 2, page 28-1. That covers only the switch, not the lock+switch. Would you be kind to point be to the section in the service manual or PM me the directions? That's be helpful ... the switch looks doable, but I can't visualize the lock part very well ... Go figure.... It is in the steering section since the lock is part of the steering column. Section - 48 08 55 Replacing steering lock.
  22. Replacement is covered in the service manual - which is what dmcole used.
  23. Impressive - most cars won't hold a vacuum overnight.
  24. Try 1099 or 1097 Nope, neither worked. In fact, the dealer gave me Code 2101 based on SN and VIN and it doesn't work. Any suggestions? Did you read this... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
