  1. No charge for Contributing Members - so you are good.
  2. I am not sure the Classified section works on Tapatalk. Please use a computer.
  3. I had to approved your ad. Also, you marked it as a completed sale. It is approved now and has all the contact info as well I made it open again.
  4. Please post in the Classified's section.
  5. Could be the solenoid in your ICV is gotten weak. After all it is 20 years old. Yes, the MAF does nothing at idle. It comes into play above 4000 RPM.
  6. The original posters issue was likely caused by wheel/tire slip on wet or dirt covered pavement.
  7. If you are using a power bleeder (pressure bleeder) getting air in is almost impossible.
  8. Reset procedure: Reverse the battery for few seconds - then reinstall it correctly. If that does not work then try re-programming. If that fails you likely will need new key (electronics).
  9. N 910 292 02 Hex-collar bolt -- US MSRP $4.03 each (8 per car)
  10. I assume this is for a 2012 (USA) Cayenne? Which parts do you need and do you have the correct rear bumper to start with?
  11. Lame... I would clear the code and see if it comes back.
  12. Hmm... you may need to talk to Durametric. In my diagnostic manuals CAN Gateway fault codes all start with C12xxx.
  13. Didn't take the time to read the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/ OPC."
  14. As jbassman6 said best do a full car scan and see what all has faults. May be simple items on some.
  15. Not sure who told you that you need an additive but Porsche does not recommend any additives. I have owned Porsche's over 40 years and have never used (or needed) an additive.
