  1. Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  2. Lost Radio Code - FAQ, PLEASE READ THIS FIRST No, post in the link at the end of the FAQ - please.
  3. Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  4. Model and year of your car please?
  5. Loren would be able to replace the buckle, Before I removed the seat I had to unplug the electric clip that controls the seat, could that have anything to do with it? None of the testers that I know of at Autozone can reset airbag lights. You can only reset an airbag light with the Durametric software, a PST2 or PIWIS tester. I had this exact same problem today. I removed the drivers side seat to get to the fried module underneath, and when I put everything back together, I had the airbag light on. I discovered I did not have the electrical connector for the seat properly connected, but after correcting this, the light is still on. I also disconnected the battery, but that did not clear it. Does that mean it will stay on until reset by one of the methods described above? The Durametric software, a PST2, or PIWIS will tell you exactly what turned the light on - and allow you to turn it off once the problem has been fixed.
  6. You will need the Durametric software, a PST2, or PIWIS tester to read the alarm fault codes. Most Porsche independent shops have at least one of these.
  7. That does not exist - you would need to make your own.
  8. http://www.renntech.org/forums/index.php?s...post&p=2107
  9. Loren would be able to replace the buckle, Before I removed the seat I had to unplug the electric clip that controls the seat, could that have anything to do with it? None of the testers that I know of at Autozone can reset airbag lights. You can only reset an airbag light with the Durametric software, a PST2 or PIWIS tester.
  10. The ICV should turn freely and not be all gummed up. It is a solenoid so you can put 12 volts to it and see/hear if it actuates. I have seen them so sticky they won't move and I have also seen bad solenoids.
  11. Those shots were taken on my PST2 using the Instrument cluster Actual Values. If you cover the sensor in the cluster it should change dramatically - likewise if you shine a flashlight at it.
  12. That means you have an "open" alarm zone. A working alarm does not beep at all.
  13. It is a different circuit depending on whether you have the rain sensor option (M265) or not. Do you have this option?
  14. :welcome: Your dealer needs to brush up on his service bulletins. If you go to our TSB (Technical Service Bulletin) page for the Cayenne (here) and do a search for PCM it will come back with 20 TSBs for PCM systems. Updates, installs, and of course fixes for problems. Our Contributing Members here can read these TSBs here online. Your dealer should put their PIWIS tester on the car and check for PCM/MOST fault codes. They can test and diagnose the system with the tester too.
  15. There is a sensor that looks at ambient light to control the cluster brightness. If you have a PST2, PIWIS, or Durametric software you should be able to test the sensor.
  16. Try 8518 or 8516
  17. As Richard Hamilton said "You really need to get a diagnostic check done with a PST2, PIWIS, or Durametric and see what fault codes come up." These testers will tell you exactly what is wrong - no guessing.
  18. Things to look at: 1. Check the ground wire from the engine to chassis (near the spark plugs it is on the right side of the car on a Carrera but I don't remember which side on a Boxster). 2. If the car was outside there is a chance the alarm box (under the drivers seat) got wet. To check, disconnect the battery; remove the drivers seat and remove and open the box looking for water damage.
  19. P1818 Pressure regulator 2 Possible fault cause: - Short circuit to B+/ground/mutual short circuit or open circuit - Pressure regulator is faulty - Tiptronic control module is faulty P1823 Pressure regulator 3 Possible fault cause: - Short circuit to B+/ground/mutual short circuit or open circuit - Pressure regulator faulty - Tiptronic control module is faulty
  20. Have you tried locking the car manually with the key and then unlocking it the same way (to reset the alarm system)? Is this a US/Canada car or RoW? Where are you located?
  21. Please do a search for OBC hack - this has been covered here in great detail many times.
  22. Hi Loren, Do you happen to know how to get the code for a becker cdR220. It's s/n is 15009805. It's in my 2002 boxster s. Thanks, Ryan Try 5227 or 5225 I tried both of those plus 5226 but no luck. Any other thoughts? Thanks much for the quick response... Ryan Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  23. Try 9920 or 9918
  24. Hi Loren, Do you happen to know how to get the code for a becker cdR220. It's s/n is 15009805. It's in my 2002 boxster s. Thanks, Ryan Try 5227 or 5225
