  1. http://www.renntech.org/forums/index.php?s...ost&p=14568 http://www.renntech.org/forums/index.php?s...ost&p=16446
  2. That is within spec (per TSB 8/02 1360 Dual Mass Flywheel Check Procedure -- dated 12/13/02) All TSBs are available for online viewing by our Contributing Members.
  3. It is about 5 hours work without alignment. Even in the pricey SF Bay Area there are good shops that will do it for $800.
  4. Do you mean find one to buy or find it in the car?
  5. If it happened after jacking onthe engine then it is likely engine mounts.
  6. :welcome: Sorry, I am not up on all my 944 parts - but here is the AC diagram and parts list. The last item on the list (not shown on the diagram) is a part called "sleeve" - perhaps this is it? my83_944_AC.pdf
  7. Try 8558 or 8556
  8. Do you want the 997 Turbo Aerokit set? What car do you want to put these on?
  9. :welcome: The headlights and fenders changed in MY02 so they will not fit a MY01 and older car. You need to look for headlights from a MY01 or older car. Your choices will be Halogen (stock) or Litronic (optional Xenon). Both easily plug in.
  10. Try 8502 or 8500
  11. Can you post a picture? I gave you a parts list diagram for the part number you gave me - where did you get the part number?
  12. Item 2 - 997.504.863.00.01C Rubber Lip SIll Cover -- US MSRP $12.03 Any Porsche dealer should have it.
  13. Probably some tech dropped it when working on your car. It is used on all the 997 models (997, GT3, and 997TT).
  14. Try 0509 or 0507
  15. At this point you need to put it on a scan tool that can read TRA, FRA and air flow (over the MAF). With these numbers you should be able to see what is really going on.
  16. You will need to connect ALL (4) of them.
  17. Sounds like a bad NAV unit - only fix is replacement.
  18. Remove the headlight from the body panel and check the connector that stays inside the fender. Look to see if it is broken or if any wires have pushed out. If all of that is okay you likely have a bad headlight switch.
  19. The brake sensors wires complete the circuit. If you cut them then they are always open. They need to be connected to turn the light off.
  20. Try 9585 or 9583
  21. :welcome: Do you item 14 - rear air duct (for rear brakes)?
  22. My mistake I misread your request. I think you want item 13? 999.500.092.00 Nut -- US MSRP $3.02 each
  23. Try 9387 or 9385 First code works, thank you , donation just processed. Thank you for your donation!
  24. You can order a replacement if you have the lock key code. Sometime they write this in your maintenance manual (my dealer did).
  25. Item 16? If so it is 996.502.017.05.GRV cross panel -- US MSRP $182.31
