  1. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  2. Porsche time units are 100 TU = 1 hour. So the estimate is 8.1 hours.
  3. Please do a search for P1130 on the forum - this has been covered many many times. It is NOT an O2 sensor - more likely a dirty or bad MAF or intake leak.
  4. Your car is a 996TT - different engine different fault diagnosis. P1133 Oxygen Sensing Adaptation, Lower Load Range, Bank 2 - Below Limit Possible fault cause: ♦ Incorrect signal from MAF sensor ♦ Fuel pressure too high ♦ Fuel injector leaking
  5. No, no tool can do that since they are not stored. Durametric, PST2 and PIWIS can graph trends of real time data (while connected).
  6. Try 2835 or 2833
  7. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  8. Durametric software, Porsche PST2 or Porsche PIWIS tester.
  9. You will need special drop links if you are using GT2/GT3 swaybars. You can get them from Carnewal.com
  10. Speakers in the door panels of a MY99 C2/C4 were part of the optional sound system (M490). I have a MY99 without door speakers (from the factory) since it does not have option M490 -- door pockets instead.
  11. Sunset Imports is NOT a Rennlist sponsor -- they ARE a RennTech.org sponsor ;)
  12. Sounds like the K&N may have fouled your MAF. You can try cleaning it - or replace it.
  13. Why don't you buy the Durametric software and get all the cars actual values and ability to plot them on a graph?
  14. What happens if you wiggle the key in the ignition?
  15. Try 5344 or 5342
  16. You could also re-program the DME to use the RoW program (which ignores the 2nd O2 sensors). Of course, you would not pass any US smog tests.
  17. Hmmm... never heard of a law like that in Illinois. Is there some hack for this? Or something that can be purchaed to fix this? Pennsylvania is one state that does not allow the use of (any) fog lights unless there is fog. There is nothing to fix - your Porsche rear fogs are operating as spec'ed by Porsche.
  18. It is now on the CAN network so unless your shift light can operate on CAN you are out of luck. This has been discussed here in more details - do a search if you want more info.
  19. In the US there is only one rear fog light - on the left rear. Some states prohibit using fog lights when there is no fog.
  20. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  21. Have you tried both keys (with remotes)? If so, you likely need to find a dealer that can re-program them for you. If re-programming does not work then you will need to buy a new remote.
  22. You are likely going to have to measure it and check it against the following list.
  23. Just drive it enough so that it can re-learn the program and then use a battery tender instead of disconnecting the battery.
  24. Because that will erase the stored driving program in the DME (engine computer) and the car will have to re-learn it over each time you do.
