  1. :welcome: Sorry, I am not up on all my 944 parts - but here is the AC diagram and parts list. The last item on the list (not shown on the diagram) is a part called "sleeve" - perhaps this is it? my83_944_AC.pdf
  2. Do you want the 997 Turbo Aerokit set? What car do you want to put these on?
  3. :welcome: The headlights and fenders changed in MY02 so they will not fit a MY01 and older car. You need to look for headlights from a MY01 or older car. Your choices will be Halogen (stock) or Litronic (optional Xenon). Both easily plug in.
  4. Can you post a picture? I gave you a parts list diagram for the part number you gave me - where did you get the part number?
  5. Item 2 - 997.504.863.00.01C Rubber Lip SIll Cover -- US MSRP $12.03 Any Porsche dealer should have it.
  6. Probably some tech dropped it when working on your car. It is used on all the 997 models (997, GT3, and 997TT).
  7. At this point you need to put it on a scan tool that can read TRA, FRA and air flow (over the MAF). With these numbers you should be able to see what is really going on.
  8. You will need to connect ALL (4) of them.
  9. Sounds like a bad NAV unit - only fix is replacement.
  10. Remove the headlight from the body panel and check the connector that stays inside the fender. Look to see if it is broken or if any wires have pushed out. If all of that is okay you likely have a bad headlight switch.
  11. The brake sensors wires complete the circuit. If you cut them then they are always open. They need to be connected to turn the light off.
  12. :welcome: Do you item 14 - rear air duct (for rear brakes)?
  13. My mistake I misread your request. I think you want item 13? 999.500.092.00 Nut -- US MSRP $3.02 each
  14. Try 9387 or 9385 First code works, thank you , donation just processed. Thank you for your donation!
  15. You can order a replacement if you have the lock key code. Sometime they write this in your maintenance manual (my dealer did).
  16. Item 16? If so it is 996.502.017.05.GRV cross panel -- US MSRP $182.31
  17. Interesting... so if you are in an accident and damage one you can not get a replacement?
  18. The bumperplugs.com painted consoles look like factory paint jobs - but I do not know their process. I would image there is some sort of modifier in the paint for the flexibility of the plastic and heating and cooling changes.
  19. 986.504.119.00 Cover Rear -- US MSRP $105.58 (as of Aug 1, 2008) Based on that it looks like Pelican is selling at full retail -- you might want to try Sunset Imports (Porsche Parts at Dealer Cost).
  20. You can not use the CDR-23 in a non-MOST (fiber optic) car. I do not know of any way to "bypass" the security code. For your CDR-220 Try 9618 or 9616
  21. My parts list and price still show the mirror as available - but Jeff may have inside information.
