  1. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  2. All TSBs are online here and available to view by Contributing Members.
  3. How about Santa Clara? http://www.wheeltechniques.com/
  4. Did you taker the mufflers off first? It really is a lot easier with the mufflers off.
  5. :welcome: Use only tire mounting lubricant and it will evaporate away one when dry/hot.
  6. We have a minimum $25 donation (mainly due to transaction costs). More info on donating here. What you get as a Contributing Member here.
  7. :welcome: How to become a Contributing Member
  8. Did you check the TSBs on this subject?
  9. Is a TSB a recall as well? From the Glossary at the top right of any page: TSB Technical Service Bulletin. Porsche issues TSB's for part number changes, installation of options and accessories, approved oils, tires, wheels, etc. Recalls are NOT covered in TSB's.
  10. The hardware is basically the same as a real PST2. Realize that PST2 was discontinued in 2004 so it does not support (and will not be updated) for the later model cars. It all comes down to trusting the seller on eBay.
  11. I have the exact same problem on my 99 996 cab trying to connect with Durametric. I can only see the ECU info. Can't see any of the module. "Module Failed to Initialize" Any idea what might be causing this? Thanks, Fred You need to send a support request to Durametric - http://www.durametric.com/support.aspx
  12. You need to find where exactly the leak is coming from.
  13. Sounds like a bad switch and perhaps lock too.
  14. Did you try relieving the pressure on the steering wheel - by turning slightly in each direction?
  15. :welcome: Have your dealer check your car for TSB 7/03 3250 Tiptronic Transmission - Oil Leak In Torque Converter Area -- dated Dec 18, 2003.
  16. :welcome: Please try our Search feature. This has been covered here literally hundreds of times...
  17. Has the cluster ever been out? Any chance that a connector is loose?
  18. Yes, they are different but I do not know the differences. 997 - 997.111.221.03 and 997.111.222.03 997 S - 997.111.421.04 and 997.111.422.04
  19. Try 7657 or 7655 Thanks for that Loren. Tried both with no luck. Just waiting for the 60 minutes to expire to try the '2 rule'. Many thanks for all your help - you really are #1... W No luck. Tried 7653, 7655, 7657, 7659 and 7661. Oh well, never mind! Thanks for trying Loren, much appreciated! Does it matter to where the radio/car is shipped? I'm in the UK. W No, country does not matter if it works then it works if it doesn't then it doesn't. You did get the serial number from the FAQ procedure not off a card in the car? Got the serial number by pressing TP for 10 seconds then turning the right hand knob as per your earlier instructions... W Then you can try the other things in the FAQ.
  20. Try 7657 or 7655 Thanks for that Loren. Tried both with no luck. Just waiting for the 60 minutes to expire to try the '2 rule'. Many thanks for all your help - you really are #1... W No luck. Tried 7653, 7655, 7657, 7659 and 7661. Oh well, never mind! Thanks for trying Loren, much appreciated! Does it matter to where the radio/car is shipped? I'm in the UK. W No, country does not matter if it works then it works if it doesn't then it doesn't. You did get the serial number from the FAQ procedure not off a card in the car?
  21. No relay. Here is a link to the 996 DIY - the Boxster will be the same except that the transmission is turned 180 degrees and you will likely have to remove some support panels to reach it. Replacing Reverse Lights/Back-Up Lights Switch
  22. Start by checking fuses. B5 is the backup lights and B10 is the parking assistant. If both are fine then you likely have a bad backup light switch (on the transmission).
  23. :welcome: Please tell us the year and model of your car -- and whether it is a 5-speed, 6-speed, or Tiptronic.
