  1. Please try a search - these have been covered many times. http://www.renntech.org/forums/index.php?s...ost&p=14785
  2. You can try cleaning the buckle contacts (as described here elsewhere) and checking for pinched wires... or if that does not work then you need to replace the buckle.
  3. Airbag Fault codes 47, 48, 49,51 = Buckle, passenger side
  4. http://www.renntech.org/forums/index.php?s...ost&p=14785
  5. The light switch sometimes will become intermittent so there is no test other than trying a new one.
  6. Here are the pin outs and wire colors (MY08 Turbo).
  7. Loren
    gauge failure
    If you know someone with the Durametric software, a PST2 or PIWIS have them run a scan on the instrument cluster.
  8. The light switch is not difficult - it has been covered here before several times.
  9. WHILE I'M HERE... Here's the VIN: WP0AA299X3S620071 I'd love to know more about my car. For example, I know x51 adds power. What does this option involve? Thanks again! You can run your VIN through Scouser's VIN Decoder (under the Documents menu at the top of any page). Contributing Members here can get more VIN information on their cars factory options.
  10. OBD2 = On board diagnostics version 2 (required on US cars and used universally by most car makers worldwide) ORVR = Onboard Refueling Vapor Recovery (required on US cars) M434 is usually special work instructions
  11. I know that - I was just trying to help by giving you the part number and the retail pricing.
  12. Could be just a shot of silicone spray or could be a failing part. But yes, uncommon.
  13. 955.111.981.00 Left tail pipe -- US MSRP $636.31
  14. Sounds like another bad ignition switch...
  15. :welcome: Hmm... try wiggling the ignition key (while switched on). A bad ignition switch can cause all kinds of weird electrical problems.
  16. If you are still under warranty let the dealer fix it.
  17. Check the polyrib belt first.
  18. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  19. +1. I think I had about 3 smaller extensions to get to them. I used multiple short extensions, it was definitely a pain in the rear to change out the plugs (must have relatively small hands). +1 on the PITA. I ended up removing the rear bumber and mufflers to get good access to the most difficult plug holes. JP The trick to making this job easier is removing the mufflers not the bumper. See the DIY for more on this.
