  1. Try 4244 or 4242 Thanks Loren, but no luck (I have also tried 4241 and 4243) :( Any other codes i can try? Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  2. Wire colors will depend on model year and RoW vs. US.
  3. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  4. Try 6673 or 6671 Donations are one-time - but many folks do donate yearly. Thanks.
  5. I would sure press the dealer for that.
  6. 15 minutes DIY.
  7. Try 3696 or 3694 +>> No luck - it should just take it, no? or should I push something afterwards? Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST +>> Still no luck. Any other numbers that you think might work? Thanks. Did you read the FAQ??? :help: YES. I know how to enter the number now; but neither number you provided worked. (I tried 3690, 3692, 3694, 3696, 3698.) "If that does not work then you will need to contact a dealer or Becker. Becker charges to lookup your code and some dealers do too."
  8. Try 3696 or 3694 +>> No luck - it should just take it, no? or should I push something afterwards? Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST +>> Still no luck. Any other numbers that you think might work? Thanks. Did you read the FAQ???
  9. Try 2687 or 2685 thanks for the attempt, but neither worked Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  10. Try 2698 or 2696 Thanks for your very speedy response, unfortunately neither of these work :( Any other guesses? Thanks again for all your help... Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  11. Sorry, the only place you can get a PCM code is from a dealer/OPC.
  12. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  13. That won't make any difference - the airbag circuit activates if the key is in the ignition (on or off).
  14. Likely DRL (Daytime Running Lights) or Intermittent wiper function, etc.
  15. Looks like it was a DRL mod (not standard).
  16. Have someone check it with a PST2 or PIWIS - airbag controller do go bad.
  17. Try 3696 or 3694 +>> No luck - it should just take it, no? or should I push something afterwards? Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  18. Sorry, the parts list nor TSB break down that part number. See if the folks at Sunset can read the part numbers off the packages in the kit for you.
