  1. If you have a factory amp it would be next to the CD changer.
  2. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  3. They should be the same - B4 is the model color and B9A is the paint part number code.
  4. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  5. Hey Bro, listening to the video it sounds like U may have some people stuck in ur engine......... may be the 1st problem!! Do u have any coolant leaking? That would be #1 for a water pump I would think. I had similar noise, but I also had coolant all over the place, may be ur water pump starting to go. I had about an inch of lateral movement in mine.....whoops Good luck! could it be the coils If it were coils he would a CEL and many faults.
  6. Try 0057 or 0055 Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  7. Yes - this has been covered here many times before. http://www.renntech.org/forums/index.php?s...ost&p=56360
  8. Per the factory TSB: "On vehicles that are still under warranty, the replacement of all bar ignition modules (coils) with Part No. 948.602.104.00 or 948.602.104.01 with bar ignition modules (coils) with Part No. 948.602.104.03 can be claimed under warranty using the following damage code: Damage Code 2820 12 000 On vehicles that are no longer covered by warranty, we also recommend that you replace all bar ignition modules (coils) with Part No. 948.602.104.00 or 948.602.104.01 following consultation with the customer with bar ignition modules (coils) with Part No. 948.602.104.03 in the event of a complaint. The replacement of bar ignition modules (coils) with Part No. 948.602.104.03 that are diagnosed as faulty can be claimed under warranty."
  9. Not really - it depends on the car and the options.
  10. B9A is the paint code for a 997 GT3 that is Carrera White.
  11. Check your batteries specific gravity (of each cell) and have it load tested. If you are sure your battery is good then check your ignition switch and ground cables on the engine/transmission.
  12. Clutch interlock will have one brown wire and one Yellow/Violet wire. Cruise control will be one black wire and one Yellow/Green wire.
  13. Which rear door - left or right? There is a violet/white wire on each door lock button (to A1). This wire goes to B1 on the left rear door controller box or B13 on the right rear door control box.
  14. Moved this topic to the proper - 986 section.
  15. These schematics are only available in PIWIS so all I can do is take a screen shot of small portions of them.
  16. They will need both old and new keys to program the immobilizer to the new key(s).
  17. ... or even a bad/intermittent TPS.
  18. Manual A/C only and heated seats. For 987's to MY07 it is: 997.653.113.12.FMH For 987's MY08 on it is: 997.653.113.13.FMH Sorry, I do not know the difference.
  19. The locks are on one schematic and the speaker on another - which do you need?
  20. The latter one includes seat heating and the previous number does not.
  21. I have the same problem too. Going to look at the weekend. Is the sensor accesible from the top or through the arch liner? Easiest to just remove the wheel and wheel well liner - then everything is accessible.
  22. On the bottom outside of the tank.
  23. Um... you can't do that unless both parties have their unique IPAS codes.
