  1. You didn't read the Lost Radio Code FAQ ... "CDR-23 (or later): These radios do not have a security code - that is, not that the user enters. These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  2. You did not read the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/ OPC."
  3. I think each car is different in it's wear and tear on suspension components. For instance, if you heavily track your car there is a lot more stress put on all suspension parts. Inspection is the key (IMHO) - look for cracks in metal components or wear points. Look for cracked or damaged rubber parts. You can measure spring height side to side and replace if they are out of spec (that is without the the shocks - just springs).
  4. Because if you get oil (of any kind) on the O2 sensors - they are toast.
  5. Did you check for blown fuses and pinched wires?
  6. Send me your VIN in a PM - I will return your info in a PM.
  7. Likely a bad pump or leaking lines.
  8. I am not sure f all the features of the Porsche Rear Seat Entertainment II but the earlier version had wireless infra-red headphones.
  9. Correct MAF part number for your car? Correct throttle body/butterfly for your car? PM me your VIN and I can double check it tomorrow.
