  1. If it is brown with a blue stripe then it for the external temperature sensor.
  2. If the battery is nearly 5 years it old then it's time has come and gone. I would replace it before it strands you somewhere. Chances are the warning light is an intermittent microswitch in the front latch.
  3. It is a pretty simple circuit but it is controlled through the OBC. Best to look at it with a PIWIS tester and see if it lost any coding.
  4. RFM is right - you likely need a PST2 or PIWIS tester to see which microswitch is not working.
  5. Both high and low beams? What happens if you wiggle the switch back and forth?
  6. :welcome: P1126 Oxygen Sensing Adaptation, Lower Load Range, Bank 1 – Above Limit P1133 Oxygen Sensing Adaptation, Lower Load Range, Bank 2 – Above Limit Potential causes: – Incorrect signal from MAF sensor – Intake air system leaking – Fuel pressure too low – Volume supply of fuel pump too low – Fuel injectors fouled P1130 Oxygen Sensing Adaptation, Idle Range, Bank 2 – Above Limit Potential causes: – Incorrect signal from MAF sensor – Intake air system leaking – Fuel pressure too low – Volume supply of fuel pump too low – Fuel injectors fouled – Exhaust system leaking The problem is not your O2 sensors. The first place to start is the MAF. Your mechanic should know he needs to look at the MAF readings at idle and 2500 RPM. If there are not within spec then the MAF needs to be cleaned or replaced.
  7. No screws - just really tight clips. It hinges towards the rear of the car so use a trim tool to carefully lift a corner and then work your way to the center back (from each side).
  8. :welcome: What is your VIN? I will run it for you. M032 is standard suspension. M273 is electrically adjustable heated door mirrors. A209 was the gas cap recall. They were supposed to put a sticker on the car when they did the recall (stating it was done).
  9. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  10. I will send you a PM.
  11. We have added three new MY2010 Order Guides. MY10 997 GT3 Order Guide MY10 Cayenne Transsyberia Order Guide MY10 Panamera Order Guide Many thanks to the member that acquired these for us.
  12. Thanks, Loren! Would steel grey not be the same as aluminum finish on the parts list? No, they show as different parts. If you can give me the part number off your old speedometer I can likely tell you which it is. Thanks again Loren. I will have the car taken apart next week. When the original dials are out, I will send you the part numbers. Loren, How about this part number 964 641 984 60. Could this be aluminum face with kms with single scale? Thnaks! Yes, it could aluminum face (Canada) only. Interesting it does not show on my parts list - but does show on my price list. Are you saying there is a code with this part number which refers this a Canada only gauge? Could you please give me the price? Thanks. US MSRP $649.07 Try Sunset Imports for better pricing.
  13. Thanks, Loren! Would steel grey not be the same as aluminum finish on the parts list? No, they show as different parts. If you can give me the part number off your old speedometer I can likely tell you which it is. Thanks again Loren. I will have the car taken apart next week. When the original dials are out, I will send you the part numbers. Loren, How about this part number 964 641 984 60. Could this be aluminum face with kms with single scale? Thnaks! Yes, it could aluminum face (Canada) only. Interesting it does not show on my parts list - but does show on my price list.
  14. Those go at the bottom of your air cleaner hosing to hold it in place.
  15. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  16. Try 0999 or 0997 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Hey loren I tried everything from 0991 -1009 I just entered and waited no response any suggestions Yes. READ THE FAQ.
  17. I assume your car is under warranty. Why not let the dealer take care of it?
  18. Robert Bosch LLC 38000 Hills Tech Drive Farmington Hills, MI 48331 By telephone: 248-876-9000 By fax: 248-876-1116 Boschautomotive@us.bosch.com
  19. And if he means hubs - then yes they can be painted - just be sure to mask the rotor surfaces.
  20. Try 8921 or 8919 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  21. thanks for the response guys! JeTexas, im thinking those mods are adding more air in the car and its overly compensating with oil and fuel? i'am also getting less mpg than originally when i had the cars w/o modifications. im not complaining about mpg though, more oil consumption than anything else. any feel for your 996 oil consumption over a 1000 mile period anyone? Zero, nada, zippo oil usage, ever. But, then again, I only use Mobil 0W40 for keeping the door hinges from squeaking. Move to the Mobil 15W50 I suggested above as it has better cleaning agents than any of the other Mobil synthetics. I have yet to see an engine that burns oil using Mobil 0W40 that did not substantially reduce or eliminate oil burning. Please don't start this oil debate again - you have voiced your opinion many times on this. Thank you. If it continues I will close this thread.
  22. :welcome: It would be a lot more helpful if you would tell us the model and year of your car. And, whether it is a US/Canada car or RoW.
  23. Thanks, Loren! Would steel grey not be the same as aluminum finish on the parts list? No, they show as different parts. If you can give me the part number off your old speedometer I can likely tell you which it is.
